While sending TI order API request, it show unauthorized error with Fault string
Hi Sree,
You are authenticating with a key that is enabled only for the v1 sandbox store API. That key is not, and cannot be, enabled for the v2 store API.
In order to use the v2 store API suite, you will need to follow the steps on https://www.ti.com/api to register a company account and request v2 store API keys. I believe that you'll find that the company account for which your checkout profile is checkout profile belongs has not yet requested API access.
I hope that helps. Let me know if you need anything else.
Paul
Hi Sree,
Thanks for submitting the API request. There has been a high volume of requests, so the approval process is taking longer than anticipated. We are working through the open requests as quickly as possible, and appreciate your patience.
Until the approval is complete, the order API cannot be tested. You were auto-approved for the TI store inventory and pricing API, though, if you'd like to call that API to ensure that you can authenticate with your new API key and secret.
Paul
