The Api don't have client id
Only have client secret
After a key and secret are generated, you can view your API key at any time, as your screen shows. Your secret, however, is only available once after it has been generated. If you do not have a record of your secret, you can use the Regenerate Key option and view the new key and secret - and store them in a safe place.
If you have already regenerated the key, you will need to wait 24 hours to regenerate it again.
Paul
Thanks for your help.I have got the secret and id.but
I am currently using the test order API .but it gets errors.
the following error:
"error": [ { "errorCode": "ERR-TICOM-ORDER-API-0009", "type": "K9", "section": null, "field": null, "reason": null, "message": "K9 Failed", "data": null } ]
The reason field is null, and I'm unsure of what the message "K9 Failed" signifies.
Could you provide guidance on how to resolve this issue?
