I´m trying to use the backlog-order-API and my first try returned following error
<code>TI-SOC-50000</code>
<type>ERROR</type>
Is the problem the character "/" at partnumber?
<type>ERROR</type>
Hi Mark,
The "/" is fine. You need to insert the brackets "[]" around the "schedules" section. See example below.
Please re-try and let me know if this works, then, I'll close this thread.
Faye
thank´s a lot - this was the problem.
May I ask about the next problem ;-) here or should I open a new issue?
errorcode --> ERR-BKG-ORDER-API-0071
reason --> Invalid shipToAccountNumber
I transmitted the shipToAccountNumber I got (beginning with 1 and ending with 9)
Is that a wrong number? (format string)
br
Michael
HI Mark,
I believe you have a space between your shipToNumber and the ")". Can you check that please?
Faye
