TI-API: [Backlog API] Invalid API call as no apiproduct match found
Part Number: TI-API
I am new to this API, and I encountered the following issue when I was running the examples on your website Backlog API suite - Quote API | TI API Portal.
I've googled, but all the answers on the forum cannot resolve my issue.
Always fail to use "Backlog quote API" and "Backlog order APIs".
We always get "Invalid API call as no apiproduct match found" when using "Backlog quote API" and "Backlog order APIs".
Precisely, the following two commands always fail.
curl -X 'POST' \
  'https://transact-pre.ti.com/v2/backlog/quotes' \
  -H 'accept: application/json' \
  -H 'Authorization: Bearer {Token hidden intentionally}' \
  -H 'application/x-www-form-urlencoded' \
  -d '{
  "quote": {
    "endCustomerCompanyName": "Company XYZ",
    "requestedUnitPriceCurrencyCode": "USD",
    "lineItems": [
        "tiPartNumber": "AFE7799IABJ",
        "quantity": 2500,
        "requestedUnitPrice": 1.2
curl -X 'POST' \
  'https://transact-pre.ti.com/v2/backlog/orders' \
  -H 'Content-Type: application/json' \
  -d '{
  "order": {
    "customerPurchaseOrderNumber": "INSERT PO NUMBER HERE",
    "shipToAccountNumber": "INSERT SHIPTO NUMBER HERE",
    "lineItems": [
        "customerLineItemNumber": "1",
        "customerAnticipatedUnitPrice": 0.202,
        "quoteNumber": "12345678",
        "customerCurrencyCode": "USD",
        "schedules": [
            "requestedQuantity": 2000,
            "requestedDeliveryDate": "2025-05-01"
Both of them responded with
   "fault":{
      "faultstring":"Invalid API call as no apiproduct match found",
      "detail":{
         "errorcode":"keymanagement.service.InvalidAPICallAsNoApiProductMatchFound"
Authentication was done successfully.
For all the codes posted here, I ran them with the token requested with the following command.
curl --request POST \
       --url 'https://transact.ti.com/v1/oauth/accesstoken' \
       --header 'Content-Type: application/x-www-form-urlencoded' \
       --data grant_type=client_credentials \
       --data client_id={ID hidden intentionally} \
       --data client_secret={secret hidden intentionally}
With this token, the "store/product" command can be executed successfully (the response is correct).
curl -X 'GET' \
  'https://transact.ti.com/v2/store/products/AFE7799IABJ?currency=USD&exclude-evms=true' \
Therefore, I consider that it's not an issue regarding authentication.
I wonder if I need to apply for permissions so that I can use "Backlog quote API" and "Backlog order APIs"?
Or anything I did was wrong?
Thanks very much for your help!
Brad
  • Hi Brad,
    As you suspected, using the backlog API suite does require additional permission. Please contact your sales representative about establishing a direct customer relationship with TI.
    Thanks and best regards,
    Paul
