Dear TI Team
We try to post remittance data via API PRD server and we got error message below. What should we do ?
Dear TI Team
Hi Paul and Sujaray,
It should have been fixed. We will validate it once customer post the data to us. Thanks.
I still got error message like this
"messages" : [
"code" : "TI-TXT-016",
"type" : "INFO",
"reason" : "invalid financialDocumentNumber",
"message" : "financialDocumentNumber is Invalid. Texas Instruments will attempt to manually match this remittance to the appropriate invoice. This may cause delays in processing. Informational only. No action required."
Do you need customerFinancialDocumentNumber ? How can I send to you
Hi Sujaray,
I just checked one API remittance advice from your side, and it posed successfully. I just request to add you to my friend, and you can send the invoice# with the issue you mentioned to me via private chat after you pass this request then I can double check whether we are checking the same data. Thanks.
Hebe
