TI-API: SAP API
Part Number: TI-API
We are facing some issue in SAP for the O Auth 2.0 as we need to pass the access token to the quotation or PO API to post the data. I verified the SAP document regarding the O Auth 2.0 and there are few SAP classes & transaction codes not available in SAP NetWeaver 7.2 which will help to config / trigger the O Auth 2.0.
We need your help if any other SAP client worked on O Auth 2.0 with the lower version of SAP NetWeaver 7.2. Could you please share if any other clients implemented similar solutions.
  • Hi Kiran,
    We have provided feedback to Alison offline, currently we only support OAuth 2.0 type authorization and we recommend you to use some other middleware that can connect TI APIGEE gateway and your SAP so that you don't need to upgrade your version.
