ADC3669EVM: Software GUI MSPS_FPGA_Server
Part Number: ADC3669EVM
Other Parts Discussed in Thread: TSWDC155EVM
Currently I am using the eval board ADC3669EVM and its capture board TSWDC155EVM.
Following the "ADC3669 Evaluation Module User's Guide (Rev. A)" it mentions that installing the GUI "ADC3669EVM_v1.0.0_installer.exe" includes "MSPS_FPGA_Server".
However, when running the the "MSPS_FPGA_Server" in the command prompt it seems certain files cannot be found. This was repeated on two different installs on two different computers and the same results. Below is the traceback.
These boards are out of the box and the software is direct from Texas Instrument's site. Any information on what is happening would be greatly appreciated. Perhaps certain files are actually missing because with a quick search of files in the traceback none could be found. Or perhaps a different software is needed in combination such as those mentioned on the "ADC3669EVM-GUI Manifest".
Thank you!
    Thank you for the detailed post. Have you followed software setup step 3a to ensure the Vivado Lab bin folder is added to your PATH system environment variable? The error you are recieving is likely due to the MSPS_FPGA_Server being unable to find the vivado .exe file needed to communicate with the FPGA. Please double check that you have this added to your PATH variable correctly.
    Luke Allen
