How can I get a single subscription notification?
You can either create or update an existing subscription by using the POST API in the Inventory and subscription API portal (https://api-portal.ti.com/inventory-subscription-push-api). Make sure the "autoSubscribe is set to false (see example below).
Reminder: Please be sure the "expiration" days is set to the max (30 days) to give you adequate time to get a response on re-stock. If you do not receive a response, you will need to re-submit your notification request.
