by trying to set up the APi I get the following error messages while trying to obtain the access token.
{ "error": "invalid_client", "error_description": "client_id or client_secret are not correct", "error_uri": "See the full API docs at ">api-portal.ti.com/order-api-authentication" }
Can you support?
Thank you
Hi Martin,
Glad you are trying to use the APIs! In general, this means that you need to supply the key and secret in order to execute the API. Without knowing which API you were executing, here is some general guidance. If this does not help, please provide me with the specific API and we'll go from there.
