What do the v1 ASN API error codes mean?
Scenario | Error details | Remediation steps |
Missing Identifier | { "Errors": [ { "Code": "TI-ASN-40010", "Message": "Provide one of the following - Purchase Order, Way Bill or Supplier Order number" } ] } |
Customer should pass at least one valid CustomerPurchaseOrderIdentifier or SupplierWayBillIdentifier or SupplierOrderIdentifier in the request. |
Only one identifier needed | { "Errors": [ { "Code": "TI-ASN-40020", "Message": "Only one of the following can be provided - Purchase Order, Way Bill or Supplier Order number" } ] } |
Customer should only pass one valid CustomerPurchaseOrderIdentifier or SupplierWayBillIdentifier or SupplierOrderIdentifier in the request. |
Sold-to number invalid or missing | { "Errors": [ { "Code": "TI-ASN-40030", "Message": "The sold-to number is invalid or missing. Provide a valid sold-to number." } ] } |
Customer should pass a valid CustomerSoldToIdentifier in the request. |
Invalid value for PDF field | { "Errors": [ { "Code": "TI-ASN-40040", "Message": "The RequestCommercialInvoicePDF and RequestWaybillPDF fields can only be 'X' or blank. Correct and resubmit. Note: 'X' means to request .pdfs" } ] } |
Customer should pass a valid RequestCommercialInvoicePDF and RequestWaybillPDF in the request. Customer should pass X in the respective fields if they want to receive a PDF otherwise the fields should be left blank. |
Server maintenance in progress | { "Errors": [ { "Code": "TI-ASN-50000", "Message": "TI server maintenance in progress. Contact TI API Support (https://api-portal.ti.com/support) support for more information." } ] } |
TI server maintenance in progress. Contact TI API Support (https://api-portal.ti.com/support) support for more information. |
No shipment data found | { "Errors": [ { "Code": "TI-ASN-40410", "Message": "Verify and correct the Purchase order OR use the Supplier Order number or WayBill number. Otherwise, there is no shipment data." } ] } |
Customer should pass a valid CustomerPurchaseOrderIdentifier and also check the status of the CustomerPurchaseOrderIdentifier. Only orders, that are completed, will have shipment data available. |
No shipment data found | { "Errors": [ { "Code": "TI-ASN-40420", "Message": "Verify and correct the Supplier order number OR use your Purchase Order or the Supplier WayBill number. Otherwise, there is no shipment data." } ] } |
Customer should pass a valid SupplierOrderIdentifier and also check the status of the SupplierOrderIdentifier. Only orders, that are completed, will have shipment data available. |
No shipment data found | { "Errors": [ { "Code": "TI-ASN-40430", "Message": "Verify and correct the WayBill number OR use your Purchase Order or the Supplier Order number. Otherwise, there is no shipment data." } ] } |
Customer should pass a valid SupplierWayBillIdentifier and also check the status of the SupplierWayBillIdentifier. Only orders, that are completed, will have shipment data available. |
Invalid identifier | { "Errors": [ { "Code": "TI-ASN-40440", "Message": "Verify and correct the sold-to identifier." } ] } |
Verify and correct the sold-to identifier. |
Missing business partner's Sold-to number | { "Errors": [ { "Code": "TI-ASN-40450", "Message": "Provide the Business Partner's sold-to identifier." } ] } |
Provide the Business Partner's sold-to identifier. |
Missing business partner | { "Errors": [ { "Code": "TI-ASN-40460", "Message": "Business Partner is required" } ] } |
Business Partner cannot be blank. Please provide and re-submit. |
