TI-API: Backlog Financial Document API status codes and meanings
Part Number: TI-API
What do the Financial Document API error codes mean?
  • Scenario Error Details Remediation Steps
    Input cannot be blank.
    	"Messages": [
    			"Code": "TI-FIR-40016",
    			"Type": "ERROR",
    			"Message": "Input cannot be blank."
    Customer should pass a valid input
    CustomerGlobalIdentifier is required.
    	"Messages": [
    			"Code": "TI-FIR-40010",
    			"Type": "ERROR",
    			"Message": "CustomerGlobalIdentifier is required."
    CustomerGlobalIdentifier is required. Contact TI API Support (api-portal.ti.com/support).
    The sold-to number is blank or invalid.
    	"Messages": [
    			"Code": "TI-FIR-40020",
    			"Type": "ERROR",
    			"Message": "The sold-to number is blank or invalid. Confirm and re-enter."
    Customer should pass a valid CustomerSoldToIdentifier in the request. This field cannot be blank.
    Sold-to number exceeds the max length of 17
    	"Messages": [
    			"Code": "TI-FIR-40030",
    			"Type": "ERROR",
    			"Message": "Provide one of the following - the document number, your reference number,the delivery number or the purchase order number."
    Customer should pass a valid CustomerSoldToIdentifier in the request. The value cannot exceed 17 characters in length
    One of four fields is required.
    	"Messages": [
    			"Code": "TI-FIR-40032",
    			"Type": "ERROR",
    Customer should only pass one valid SupplierFinancialDocumentIdentifier or CustomerReferenceIdentifier or SupplierDeliveryIdentifier or CustomerPurchaseOrderIdentifier in the request
    Only one of four fields can be populated.
    	"Messages": [
    			"Code": "TI-FIR-40034",
    			"Type": "ERROR",
    			"Message": "Only one of the following can be provided -the document number, your reference number,the delivery number or the purchase order number."
    SupplierFinancialDocumentIdentifier cannot exceed 10 characters in length.
    	"Messages": [
    			"Code": "TI-FIR-40040",
    			"Type": "ERROR",
    			"Message": "The document number can not exceed 10 characters.Verify and re-enter."
    Customer should pass a valid SupplierFinancialDocumentIdentifier in the request. The value cannot exceed 10 characters in length
    CustomerReferenceIdentifier cannot exceed 16 characters in length.
    	"Messages": [
    			"Code": "TI-FIR-40044",
    			"Type": "ERROR",
    			"Message": "Your reference number can not exceed 16 characters.Verify and re-enter."
    Customer should not exceed 16 characters in length.
    SupplierDeliveryIdentifier cannot exceed 10 characters in length.
    	"Messages": [
    			"Code": "TI-FIR-40050",
    			"Type": "ERROR",
    			"Message": "The delivery number can not exceed 10 characters.Verify and re-enter."
    Customer should pass a valid SupplierDeliveryIdentifier in the request. The value cannot exceed 10 characters in length
    CustomerPurchaseOrderIdentifier cannot exceed 35 characters in length.
    	"Messages": [
    			"Code": "TI-FIR-40060",
    			"Type": "ERROR",
    			"Message": "The purchase order number can not exceed 35 characters.Verify and re-enter."
    Customer should pass a valid CustomerPurchaseOrderIdentifier in the request. The value cannot exceed 35 characters in length.
     SupplierDocumentStatus cannot exceed 10 characters in length.
    	"Messages": [
    			"Code": "TI-FIR-40070",
    			"Type": "ERROR",
    			"Message": "The document status can not exceed 10 characters.Verify and re-enter."
     Customer should pass a valid SupplierDocumentStatus in the request. The value cannot exceed 10 characters in length.
    SupplierDocumentCreatedFromDate is not a valid date (YYYY-MM-DD).
    	"Messages": [
    			"Code": "TI-FIR-40080",
    			"Type": "ERROR",
    			"Message": "The document creation date format is YYYY-MM-DD.Correct and re-submit."
     Customer should pass a valid SupplierDocumentCreatedFromDate in the request. The valid date format is YYYY-MM-DD
    SupplierDocumentCreatedToDate is not a valid date (YYYY-MM-DD).
    	"Messages": [
    			"Code": "TI-FIR-40090",
    			"Type": "ERROR",
    Customer should pass a valid SupplierDocumentCreatedToDate in the request. The valid date format is YYYY-MM-DD
    RequestPDF can either be blank or X.
    	"Messages": [
    			"Code": "TI-FIR-40100",
    			"Type": "ERROR",
    			"Message": "Pass an 'X' in the SupplierDocumentPDF field if a PDF is desired.Otherwise the field should be blank."
     Customer should pass a valid RequestPDF in the request. Customer should pass X in the field if they want to receive a PDF otherwise the field should be left blank.
    System error occurred.
    Connection refused (Connection refused)
    	"Messages": [
    			"Code": "TI-FIR-50000",
    			"Type": "ERROR",
    			"Message": "Contact API Support with at least the following details: error code, error message and API endpoint."
    Customer should contact API support with all the details such as the error message, the error code, the API endpoint etc.
    Outage Information
    	"Messages": [
    			"Code": "TI-FIR-51000",
    			"Type": "ERROR",
    			"Message": "This API is currently unavailable between $OutageStart and $OutageEnd $timeZoneStr. Re-submit your request after the maintenance window."
    Customer will be informed of Outage information.
