TDA4VEN-Q1: TDA4VHN CPSW3G Port 2 Low Bandwidth Issue
Part Number: TDA4VEN-Q1
Hi TI experts,
We are developing using a dual-TDA4 solution. When testing Ethernet performance, we encountered an issue: the Ethernet connection between the two TDA4s (directly connected via SGMII MAC-to-MAC at 1000 Mbps) only achieves a bandwidth of less than 10 Mbits/sec when tested with iperf3, whether using TCP or UDP. Additionally, the CPU utilization rates displayed by top are very low, both on the client and server sides. Could you please help identify potential causes for this?
This is the network architecture.
IP address of A board:10.0.0.1
IP address of B board:10.0.0.2
Board B executes:"iperf3 -s -p 12345"
Board A:
TCP:
UDP:
    Can you please confirm the Link status and Speed of SGMII MAC to MAC Ports?
    Also, can you please share the logs of boot log and ifconfig info along with ethtool log.
    Sudheer
    Refer to the attached file
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.12.35-ti-00953-ge45814a3425b-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Mon Dec  1 08:15:27 UTC 2025
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Hirain spartan
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: legacy bootconsole [ns16550a0] enabled
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000000f8000000, size 128 MiB
    [    0.000000] OF: reserved mem: initialized node linux-cma-buffers@F8000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000f8000000..0x00000000ffffffff (131072 KiB) map reusable linux-cma-buffers@F8000000
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] OF: reserved mem: 0x00000000ac200000..0x00000000b81fffff (196608 KiB) map non-reusable vision_apps_shared-memories
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b8200000, size 256 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-ddr-heaps-hi@b8200000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000b8200000..0x00000000c81fffff (262144 KiB) nomap non-reusable c7x-ddr-heaps-hi@b8200000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa200000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@aa200000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000aa200000..0x00000000ac1fffff (32768 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@aa200000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8300000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@a8300000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a8300000..0x00000000aa1fffff (31744 KiB) nomap non-reusable vision-apps-c71_1-memory@a8300000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8200000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@a8200000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a8200000..0x00000000a82fffff (1024 KiB) nomap non-reusable vision-apps-c71_1-dma-memory@a8200000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6300000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@a6300000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a6300000..0x00000000a81fffff (31744 KiB) nomap non-reusable vision-apps-c71_0-memory@a6300000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6200000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@a6200000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a6200000..0x00000000a62fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@a6200000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 18 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a61fffff (18432 KiB) nomap non-reusable vision-apps-dma-memory@a5000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 16 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@a4000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a4ffffff (16384 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region@a4000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000ac1fffff]
    [    0.000000]   node   0: [mem 0x00000000ac200000-0x00000000b81fffff]
    [    0.000000]   node   0: [mem 0x00000000b8200000-0x00000000c81fffff]
    [    0.000000]   node   0: [mem 0x00000000c8200000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
    [    0.000000] pcpu-alloc: s51672 r8192 d30248 u90112 alloc=22*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: root=/dev/mmcblk0p13 rootwait ro console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 androidboot.soc_name=spartan_a
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 524288
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000f5700000-0x00000000f5900000] (2MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080450000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080460000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008783] Console: colour dummy device 80x25
    [    0.013371] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.024038] pid_max: default: 32768 minimum: 301
    [    0.028838] LSM: initializing lsm=capability,selinux
    [    0.033958] SELinux:  Initializing.
    [    0.037952] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.045518] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.055547] rcu: Hierarchical SRCU implementation.
    [    0.060485] rcu: 	Max phase no-delay instances is 1000.
    [    0.066007] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.074843] EFI services will not be available.
    [    0.079737] smp: Bringing up secondary CPUs ...
    [    0.084946] Detected VIPT I-cache on CPU1
    [    0.085018] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.085035] GICv3: CPU1: using allocated LPI pending table @0x0000000080470000
    [    0.085078] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.085777] Detected VIPT I-cache on CPU2
    [    0.085832] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.085846] GICv3: CPU2: using allocated LPI pending table @0x0000000080480000
    [    0.085876] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.086507] Detected VIPT I-cache on CPU3
    [    0.086559] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.086572] GICv3: CPU3: using allocated LPI pending table @0x0000000080490000
    [    0.086601] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.086719] smp: Brought up 1 node, 4 CPUs
    [    0.166335] SMP: Total of 4 processors activated.
    [    0.171140] CPU: All CPU(s) started at EL2
    [    0.175339] CPU features: detected: 32-bit EL0 Support
    [    0.180591] CPU features: detected: CRC32 instructions
    [    0.185882] alternatives: applying system-wide alternatives
    [    0.192159] Memory: 1209940K/2097152K available (13184K kernel code, 1270K rwdata, 4724K rodata, 2752K init, 660K bss, 747252K reserved, 131072K cma-reserved)
    [    0.207690] devtmpfs: initialized
    [    0.221842] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.231841] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.242230] 27056 pages in range for non-PLT usage
    [    0.242252] 518576 pages in range for PLT usage
    [    0.247468] pinctrl core: initialized pinctrl subsystem
    [    0.257961] DMI not present or invalid.
    [    0.264000] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.271187] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.278992] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.287658] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.295808] audit: initializing netlink subsys (disabled)
    [    0.301571] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1
    [    0.302014] thermal_sys: Registered thermal governor 'step_wise'
    [    0.309494] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.315674] cpuidle: using governor menu
    [    0.326510] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.333537] ASID allocator initialised with 65536 entries
    [    0.345800] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.370248] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.377216] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.383625] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.390557] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.396960] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.403888] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.410291] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.417223] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.425249] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected
    [    0.434496] iommu: Default domain type: Translated
    [    0.439418] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.446474] SCSI subsystem initialized
    [    0.450526] libata version 3.00 loaded.
    [    0.450714] usbcore: registered new interface driver usbfs
    [    0.456357] usbcore: registered new interface driver hub
    [    0.461817] usbcore: registered new device driver usb
    [    0.467558] pps_core: LinuxPPS API ver. 1 registered
    [    0.472638] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.481976] PTP clock support registered
    [    0.486010] EDAC MC: Ver: 3.0.0
    [    0.489530] scmi_core: SCMI protocol bus registered
    [    0.494806] FPGA manager framework
    [    0.498352] Advanced Linux Sound Architecture Driver Initialized.
    [    0.505485] vgaarb: loaded
    [    0.508615] clocksource: Switched to clocksource arch_sys_counter
    [    0.515090] VFS: Disk quotas dquot_6.6.0
    [    0.519120] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.533205] Carveout Heap: Exported 192 MiB at 0x00000000ac200000
    [    0.539541] NET: Registered PF_INET protocol family
    [    0.544670] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.553837] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.562619] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.570544] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.578737] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.586595] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.593417] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.600325] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.607791] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.614027] RPC: Registered named UNIX socket transport module.
    [    0.620099] RPC: Registered udp transport module.
    [    0.624912] RPC: Registered tcp transport module.
    [    0.629717] RPC: Registered tcp-with-tls transport module.
    [    0.635320] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.641905] NET: Registered PF_XDP protocol family
    [    0.646813] PCI: CLS 0 bytes, default 64
    [    0.652181] Initialise system trusted keyrings
    [    0.656971] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.663858] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.670080] NFS: Registering the id_resolver key type
    [    0.675279] Key type id_resolver registered
    [    0.679553] Key type id_legacy registered
    [    0.683673] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.690526] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.751010] Key type asymmetric registered
    [    0.755211] Asymmetric key parser 'x509' registered
    [    0.760248] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.767994] io scheduler mq-deadline registered
    [    0.772630] io scheduler kyber registered
    [    0.776756] io scheduler bfq registered
    [    0.783908] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.790554] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.797850] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.810409] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.825688] loop: module loaded
    [    0.830009] megasas: 07.727.03.00-rc1
    [    0.838071] tun: Universal TUN/TAP device driver, 1.6
    [    0.844380] VFIO - User Level meta-driver version: 0.3
    [    0.851072] usbcore: registered new interface driver usb-storage
    [    0.857876] i2c_dev: i2c /dev entries driver
    [    0.863447] sdhci: Secure Digital Host Controller Interface driver
    [    0.869779] sdhci: Copyright(c) Pierre Ossman
    [    0.874495] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.881069] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.888551] usbcore: registered new interface driver usbhid
    [    0.894264] usbhid: USB HID core driver
    [    0.899584] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    [    0.910045] optee: probing for conduit method.
    [    0.914614] optee: revision 4.6 (71785645fa6ce42d)
    [    0.914969] optee: dynamic shared memory is enabled
    [    0.925527] optee: initialized driver
    [    0.925631] random: crng init done
    [    0.931450] Initializing XFRM netlink socket
    [    0.937166] NET: Registered PF_PACKET protocol family
    [    0.942404] Key type dns_resolver registered
    [    0.955295] registered taskstats version 1
    [    0.959750] Loading compiled-in X.509 certificates
    [    0.976061] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.9-v11.01.09 (Fancy Rat)')
    [    1.033426] omap_i2c 4900000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.040175] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.047232] pca953x 2-0023: supply vcc not found, using dummy regulator
    [    1.054147] pca953x 2-0023: using AI
    [    1.072668] pca953x 2-0023: failed writing register: -121
    [    1.078350] pca953x 2-0023: probe with driver pca953x failed with error -121
    [    1.085931] omap_i2c 20000000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.092279] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    1.100634] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.109849] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.124151] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.132557] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16)
    [    1.143367] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.154152] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.164328] printk: legacy console [ttyS2] disabled
    [    1.169650] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 228, base_baud = 3000000) is a 8250
    [    1.178606] printk: legacy console [ttyS2] enabled
    [    1.188292] printk: legacy bootconsole [ns16550a0] disabled
    [    1.202898] spi-nor spi0.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00
    [    1.209854] spi spi0.0: chipselect 0 already in use
    [    1.214734] spi_master spi0: spi_device register error /bus@f0000/bus@fc00000/spi@fc40000/nand@0
    [    1.223529] spi_master spi0: Failed to create SPI device for /bus@f0000/bus@fc00000/spi@fc40000/nand@0
    [    1.233308] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.251460] mmc0: CQHCI version 5.10
    [    1.295256] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.313104] vcc0v85_ram_buck3: Bringing 750000uV into 850000-850000uV
    [    1.331950] j721e-pcie f102000.pcie: host bridge /pcie@f102000 ranges:
    [    1.338529] j721e-pcie f102000.pcie:       IO 0x0600001000..0x0600100fff -> 0x0000001000
    [    1.346631] j721e-pcie f102000.pcie:      MEM 0x0600101000..0x06ffffffff -> 0x0000101000
    [    1.354730] j721e-pcie f102000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    1.371758] mmc0: Command Queue Engine enabled
    [    1.376242] mmc0: new HS200 MMC card at address 0001
    [    1.381791] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
    [    1.388420] Alternate GPT is invalid, using primary GPT.
    [    1.393804]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
    [    1.403740] mmcblk0boot0: mmc0:0001 8GUF4R 31.9 MiB
    [    1.409570] mmcblk0boot1: mmc0:0001 8GUF4R 31.9 MiB
    [    1.415328] mmcblk0rpmb: mmc0:0001 8GUF4R 4.00 MiB, chardev (238:0)
    [    2.367111] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00
    [    2.373441] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    2.378928] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x1000-0x100fff])
    [    2.387964] pci_bus 0000:00: root bus resource [mem 0x600101000-0x6ffffffff] (bus address [0x00101000-0xffffffff])
    [    2.398326] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400 PCIe Root Port
    [    2.405642] pci 0000:00:00.0: PCI bridge to [bus 00]
    [    2.410607] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
    [    2.416695] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
    [    2.423480] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
    [    2.431274] pci 0000:00:00.0: supports D1
    [    2.435282] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [    2.443946] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    2.452138] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [    2.458770] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    2.463737] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
    [    2.469395] pci_bus 0000:00: resource 5 [mem 0x600101000-0x6ffffffff]
    [    2.475944] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
    [    2.482897] pcieport 0000:00:00.0: PME: Signaling with IRQ 474
    [    2.489042] pcieport 0000:00:00.0: AER: enabled with IRQ 474
    [    2.495458] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    2.509563] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    2.516429] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    2.556630] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    2.570039] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver NXP C45 TJA1103
    [    2.578922] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    2.586068] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    2.593912] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:1
    [    2.612507] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    2.624813] clk: Disabling unused clocks
    [    2.633957] PM: genpd: Disabling unused power domains
    [    2.639101] ALSA device list:
    [    2.642140]   No soundcards found.
    [    2.655797] EXT4-fs (mmcblk0p13): orphan cleanup on readonly fs
    [    2.662084] EXT4-fs (mmcblk0p13): mounted filesystem d87f5611-b496-43b6-9088-71a61aa702c9 ro with ordered data mode. Quota mode: none.
    [    2.674250] VFS: Mounted root (ext4 filesystem) readonly on device 179:13.
    [    2.681441] devtmpfs: mounted
    [    2.685206] Freeing unused kernel memory: 2752K
    [    2.689826] Run /sbin/init as init process
    [    2.693933]   with arguments:
    [    2.693937]     /sbin/init
    [    2.693941]   with environment:
    [    2.693944]     HOME=/
    [    2.693948]     TERM=linux
    [    2.784552] systemd[1]: System time before build time, advancing clock.
    [    2.813003] NET: Registered PF_INET6 protocol family
    [    2.818948] Segment Routing with IPv6
    [    2.822671] In-situ OAM (IOAM) with IPv6
    [    2.845365] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.877485] systemd[1]: Detected architecture arm64.
    [    2.889745] systemd[1]: Hostname set to <spartan>.
    [    2.896913] systemd[1]: Initializing machine ID from random generator.
    [    2.903670] systemd[1]: Installed transient /etc/machine-id file.
    [    3.325232] systemd[1]: Queued start job for default target Multi-User System.
    [    3.376961] systemd[1]: Created slice Slice /system/getty.
    [    3.394555] systemd[1]: Created slice Slice /system/modprobe.
    [    3.414453] systemd[1]: Created slice Slice /system/serial-getty.
    [    3.434490] systemd[1]: Created slice Slice /system/systemd-fsck.
    [    3.454496] systemd[1]: Created slice Slice /system/systemd-makefs.
    [    3.473969] systemd[1]: Created slice User and Session Slice.
    [    3.493066] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.512960] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.532826] systemd[1]: Expecting device /dev/disk/by-partlabel/data...
    [    3.552728] systemd[1]: Expecting device /dev/disk/by-partlabel/update...
    [    3.572853] systemd[1]: Reached target Path Units.
    [    3.588775] systemd[1]: Reached target Remote File Systems.
    [    3.604761] systemd[1]: Reached target Slice Units.
    [    3.620770] systemd[1]: Reached target Swaps.
    [    3.637521] systemd[1]: Listening on Syslog Socket.
    [    3.653898] systemd[1]: Listening on Journal Audit Socket.
    [    3.673354] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.693415] systemd[1]: Listening on Journal Socket.
    [    3.709546] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.729514] systemd[1]: Listening on udev Control Socket.
    [    3.749281] systemd[1]: Listening on udev Kernel Socket.
    [    3.765341] systemd[1]: Listening on User Database Manager Socket.
    [    3.808991] systemd[1]: Mounting Huge Pages File System...
    [    3.828398] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.852665] systemd[1]: Mounting Kernel Debug File System...
    [    3.869288] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.886054] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.909612] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.933293] systemd[1]: Starting Load Kernel Module configfs...
    [    3.957216] systemd[1]: Starting Load Kernel Module drm...
    [    3.977319] systemd[1]: Starting Load Kernel Module fuse...
    [    4.003204] systemd[1]: Starting Journal Service...
    [    4.009042] fuse: init (API version 7.41)
    [    4.022195] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
    [    4.035661] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.065380] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.093467] systemd[1]: Starting Apply Kernel Variables...
    [    4.106445] systemd-journald[115]: Collecting audit messages is enabled.
    [    4.113644] systemd[1]: Starting Coldplug All udev Devices...
    [    4.140178] systemd[1]: Mounted Huge Pages File System.
    [    4.153045] EXT4-fs (mmcblk0p13): re-mounted d87f5611-b496-43b6-9088-71a61aa702c9.
    [    4.163358] systemd[1]: Mounted POSIX Message Queue File System.
    [    4.185817] systemd[1]: Mounted Kernel Debug File System.
    [    4.205295] systemd[1]: Started Journal Service.
    [    4.473371] systemd-journald[115]: Received client request to flush runtime journal.
    [    4.619432] audit: type=1334 audit(1748544503.832:2): prog-id=6 op=LOAD
    [    4.626812] audit: type=1334 audit(1748544503.840:3): prog-id=7 op=LOAD
    [    5.311981] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    5.321776] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    5.331711] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [    5.339140] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100
    [    5.349184] mc: Linux media interface: v0.10
    [    5.365767] videodev: Linux video capture interface: v2.00
    [    5.368825] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@a6200000
    [    5.390744] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
    [    5.399377] remoteproc remoteproc0: 7e000000.dsp is available
    [    5.410605] remoteproc remoteproc0: Direct firmware load for j722s-c71_0-fw failed with error -2
    [    5.419580] remoteproc remoteproc0: powering up 7e000000.dsp
    [    5.426797] remoteproc remoteproc0: Direct firmware load for j722s-c71_0-fw failed with error -2
    [    5.435890] remoteproc remoteproc0: request_firmware failed: -2
    [    5.442212] k3-dsp-rproc 7e200000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@a8200000
    [    5.454294] k3-dsp-rproc 7e200000.dsp: configured DSP for remoteproc mode
    [    5.462047] platform 79000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    5.462999] remoteproc remoteproc1: 7e200000.dsp is available
    [    5.481192] remoteproc remoteproc1: Direct firmware load for j722s-c71_1-fw failed with error -2
    [    5.490036] platform 79000000.r5f: configured R5F for IPC-only mode
    [    5.490205] platform 79000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
    [    5.496416] remoteproc remoteproc1: powering up 7e200000.dsp
    [    5.506197] remoteproc remoteproc2: 79000000.r5f is available
    [    5.512364] remoteproc remoteproc1: Direct firmware load for j722s-c71_1-fw failed with error -2
    [    5.517111] remoteproc remoteproc2: attaching to 79000000.r5f
    [    5.525933] remoteproc remoteproc1: request_firmware failed: -2
    [    5.531653] Unable to handle kernel paging request at virtual address ffff800086ffffff
    [    5.531665] Mem abort info:
    [    5.531668]   ESR = 0x0000000096000006
    [    5.531672]   EC = 0x25: DABT (current EL), IL = 32 bits
    [    5.531677]   SET = 0, FnV = 0
    [    5.531681]   EA = 0, S1PTW = 0
    [    5.531684]   FSC = 0x06: level 2 translation fault
    [    5.531688] Data abort info:
    [    5.531690]   ISV = 0, ISS = 0x00000006, ISS2 = 0x00000000
    [    5.531694]   CM = 0, WnR = 0, TnD = 0, TagAccess = 0
    [    5.531698]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
    [    5.531703] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000083196000
    [    5.531708] [ffff800086ffffff] pgd=0000000000000000, p4d=1000000083634003, pud=1000000083635003, pmd=0000000000000000
    [    5.604763] Internal error: Oops: 0000000096000006 [#1] PREEMPT SMP
    [    5.611036] Modules linked in: rti_wdt(+) videobuf2_dma_contig v4l2_mem2mem videobuf2_v4l2 ti_k3_r5_remoteproc(+) videobuf2_memops videobuf2_common cdns_dsi videodev ti_k3_dsp_remoteproc ti_k3_common drm_kms_helper mc snd_soc_davinci_mcasp sa2ul snd_soc_ti_udma mcrc64 snd_soc_ti_edma cdns_dphy omap_hwspinlock snd_soc_ti_sdma snd_soc_tlv320aic3x_i2c omap_mailbox snd_soc_tlv320aic3x overlay fuse drm drm_panel_orientation_quirks backlight ipv6
    [    5.650079] CPU: 3 UID: 0 PID: 180 Comm: (udev-worker) Not tainted 6.12.35-ti-00953-ge45814a3425b-dirty #1
    [    5.665261] Hardware name: Hirain spartan (DT)
    [    5.670814] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [    5.677763] pc : rproc_handle_resources.constprop.0+0x64/0x18c
    [    5.683596] lr : rproc_boot+0x37c/0x584
    [    5.687426] sp : ffff80008283b640
    [    5.690729] x29: ffff80008283b640 x28: ffff800081623f00 x27: ffff00000590ae00
    [    5.697858] x26: 0000000000000000 x25: 0000000000000001 x24: ffff800086ffffff
    [    5.704985] x23: 0000000000000000 x22: ffff000004ce0838 x21: ffff800081565388
    [    5.712111] x20: 0000000000000000 x19: ffff000004ce0800 x18: 0000000000000006
    [    5.719238] x17: 737070612d6e6f69 x16: 1fffe0000089a741 x15: ffffffffffffffff
    [    5.726365] x14: ffffffffffffffff x13: ffffffffffffffff x12: ffffffffffffffff
    [    5.733491] x11: ffffffffffffffff x10: ffffffffffffffff x9 : ffffffffffffffff
    [    5.740618] x8 : ffffffffffffffff x7 : ffffffffffffffff x6 : ffffffffffffffff
    [    5.747744] x5 : ffff00000492fb00 x4 : ffff800087000000 x3 : 00000000000000fd
    [    5.754869] x2 : 00000000ffffffff x1 : ffff800087000003 x0 : ffff800087000000
    [    5.761996] Call trace:
    [    5.764432]  rproc_handle_resources.constprop.0+0x64/0x18c
    [    5.769908]  rproc_boot+0x37c/0x584
    [    5.773389]  rproc_add+0x184/0x190
    [    5.776785]  devm_rproc_add+0x24/0x88
    [    5.780440]  k3_r5_probe+0x978/0xeec [ti_k3_r5_remoteproc]
    [    5.785924]  platform_probe+0x68/0xc4
    [    5.789580]  really_probe+0xbc/0x29c
    [    5.793150]  __driver_probe_device+0x78/0x12c
    [    5.797499]  driver_probe_device+0xd8/0x15c
    [    5.801674]  __driver_attach+0x90/0x19c
    [    5.805503]  bus_for_each_dev+0x7c/0xe0
    [    5.809331]  driver_attach+0x24/0x30
    [    5.812899]  bus_add_driver+0xe4/0x208
    [    5.816640]  driver_register+0x5c/0x124
    [    5.820469]  __platform_driver_register+0x24/0x30
    [    5.825162]  k3_r5_rproc_driver_init+0x20/0x1000 [ti_k3_r5_remoteproc]
    [    5.831681]  do_one_initcall+0x80/0x1c8
    [    5.835510]  do_init_module+0x58/0x1fc
    [    5.839252]  load_module+0x1bcc/0x1d8c
    [    5.842992]  init_module_from_file+0x88/0xcc
    [    5.847253]  __arm64_sys_finit_module+0x148/0x324
    [    5.851948]  invoke_syscall+0x48/0x10c
    [    5.855690]  el0_svc_common.constprop.0+0xc0/0xe0
    [    5.860385]  do_el0_svc+0x1c/0x28
    [    5.863693]  el0_svc+0x28/0x98
    [    5.866745]  el0t_64_sync_handler+0x120/0x12c
    [    5.871092]  el0t_64_sync+0x190/0x194
    [    5.874749] Code: 6b020063 8b22c098 91001301 540007c4 (b862c880)
    [    5.880828] ---[ end trace 0000000000000000 ]---
    [    5.902168] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    5.913425] vdec 30210000.video-codec: Direct firmware load for cnm/wave521c_k3_codec_fw.bin failed with error -2
    [    5.923853] vdec 30210000.video-codec: request_firmware, fail: -2
    [    5.930063] vdec 30210000.video-codec: wave5_vpu_load_firmware, fail: -2
    [    5.941807] vdec 30210000.video-codec: probe with driver vdec failed with error -2
    [    5.975597] CAN device driver interface
    [    5.982640] rpmsg_can_probe: v.0 enter!
    [    5.990125] net can0: can_id is 0 dev 1780000
    [    5.997980] rpmsg_can_probe: v.0 enter!
    [    6.006427] net can1: can_id is 1 dev 5860000
    [    6.015033] rpmsg_can_probe: v.0 enter!
    [    6.025361] net can2: can_id is 2 dev 5878000
    [    6.030860] rpmsg_can_probe: v.0 enter!
    [    6.041305] net can3: can_id is 3 dev 71b8000
    [    6.047558] rpmsg_can_probe: v.0 enter!
    [    6.052178] net can4: can_id is 4 dev 5830000
    [    6.056933] rpmsg_can_probe: v.0 enter!
    [    6.061586] net can5: can_id is 5 dev 72c8000
    [    6.066295] rpmsg_can_probe: v.0 enter!
    [    6.070810] net can6: can_id is 6 dev 7240000
    [    6.075488] rpmsg_can_probe: v.0 enter!
    [    6.454214] EXT4-fs (mmcblk0p16): mounted filesystem 0f2e4f14-8434-4cd4-8d4f-c8eb1bd89886 r/w with ordered data mode. Quota mode: none.
    [    6.536507] EXT4-fs (mmcblk0p18): mounted filesystem fe0d5082-c446-4377-8301-36da635d06c5 r/w with ordered data mode. Quota mode: none.
    [    6.782039] audit: type=1334 audit(1748544505.996:4): prog-id=8 op=LOAD
    [    6.820343] audit: type=1334 audit(1748544506.032:5): prog-id=9 op=LOAD
    [    6.866400] audit: type=1334 audit(1748544506.080:6): prog-id=10 op=LOAD
    [    6.873287] audit: type=1334 audit(1748544506.088:7): prog-id=11 op=LOAD
    [    6.880106] audit: type=1334 audit(1748544506.092:8): prog-id=12 op=LOAD
    [    7.533027] audit: type=1334 audit(1748544506.748:9): prog-id=13 op=LOAD
    [    7.539856] audit: type=1334 audit(1748544506.752:10): prog-id=14 op=LOAD
    [    7.546741] audit: type=1334 audit(1748544506.760:11): prog-id=15 op=LOAD
    [    7.710169] audit: type=1334 audit(1748544506.924:12): prog-id=16 op=LOAD
    [    7.791579] cgroup: Unknown subsys name 'memory'
    [    7.848227] file system registered
    [    7.951295] ffs_data_put(): freeing
    [    7.983700] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.011278] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.017886] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    8.025867] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    8.036252] cfg80211: failed to load regulatory.db
    [    8.060287] read descriptors
    [    8.063288] bcdVersion must be 0x0100, stored in Little Endian order. Userspace driver should be fixed, accepting 0x0001 for compatibility.
    [    8.075952] read strings
    [    8.211207] audit: type=1334 audit(1748544507.424:13): prog-id=17 op=LOAD
    [    8.235233] am65-cpsw-nuss 8000000.ethernet eth1: configuring for fixed/sgmii link mode
    [    8.248720] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
    [    8.300477] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:01] driver [NXP C45 TJA1103] (irq=POLL)
    [    8.310375] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-txid link mode
    [   18.338653] platform 30500000.dsi: deferred probe pending: (reason unknown)
    [   18.345649] platform 4e400000.interrupt-controller: deferred probe pending: (reason unknown)
    [   18.354085] platform 4e230000.dma-controller: deferred probe pending: platform: supplier 4e400000.interrupt-controller not ready
    [   18.365647] platform can-phy2: deferred probe pending: platform: supplier 2-0023 not ready
    [   18.373909] platform fd20000.e5010: deferred probe pending: (reason unknown)
    [   18.380961] platform connector-dp0: deferred probe pending: platform: supplier regulator-dp0-prw not ready
    [   18.390612] platform regulator-dp0-prw: deferred probe pending: reg-fixed-voltage: can't get GPIO
    [   18.399484] platform fa00000.mmc: deferred probe pending: platform: supplier regulator-mmc1 not ready
    [   18.408698] platform regulator-mmc1: deferred probe pending: platform: supplier 2-0023 not ready
    [    0.000000] Kernel command line: root=/dev/mmcblk0p13 rootwait ro console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 androidboot.soc_name=spartan_b
    [    0.008784] Console: colour dummy device 80x25
    [    0.013374] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.024047] pid_max: default: 32768 minimum: 301
    [    0.028847] LSM: initializing lsm=capability,selinux
    [    0.033971] SELinux:  Initializing.
    [    0.037963] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.045531] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.055566] rcu: Hierarchical SRCU implementation.
    [    0.060508] rcu: 	Max phase no-delay instances is 1000.
    [    0.066030] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.074876] EFI services will not be available.
    [    0.079773] smp: Bringing up secondary CPUs ...
    [    0.084993] Detected VIPT I-cache on CPU1
    [    0.085063] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.085079] GICv3: CPU1: using allocated LPI pending table @0x0000000080470000
    [    0.085123] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.085828] Detected VIPT I-cache on CPU2
    [    0.085882] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.085895] GICv3: CPU2: using allocated LPI pending table @0x0000000080480000
    [    0.085926] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.086557] Detected VIPT I-cache on CPU3
    [    0.086608] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.086622] GICv3: CPU3: using allocated LPI pending table @0x0000000080490000
    [    0.086651] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.086773] smp: Brought up 1 node, 4 CPUs
    [    0.166419] SMP: Total of 4 processors activated.
    [    0.171227] CPU: All CPU(s) started at EL2
    [    0.175426] CPU features: detected: 32-bit EL0 Support
    [    0.180681] CPU features: detected: CRC32 instructions
    [    0.185985] alternatives: applying system-wide alternatives
    [    0.192260] Memory: 1209940K/2097152K available (13184K kernel code, 1270K rwdata, 4724K rodata, 2752K init, 660K bss, 747252K reserved, 131072K cma-reserved)
    [    0.207736] devtmpfs: initialized
    [    0.221969] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.231971] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.242329] 27056 pages in range for non-PLT usage
    [    0.242352] 518576 pages in range for PLT usage
    [    0.247540] pinctrl core: initialized pinctrl subsystem
    [    0.258068] DMI not present or invalid.
    [    0.264107] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.271287] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.279107] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.287776] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.295934] audit: initializing netlink subsys (disabled)
    [    0.301694] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1
    [    0.302130] thermal_sys: Registered thermal governor 'step_wise'
    [    0.309620] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.315803] cpuidle: using governor menu
    [    0.326640] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.333666] ASID allocator initialised with 65536 entries
    [    0.345887] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.370265] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.377232] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.383643] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.390577] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.396981] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.403914] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.410318] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.417252] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.425283] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected
    [    0.435826] iommu: Default domain type: Translated
    [    0.440753] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.447872] SCSI subsystem initialized
    [    0.451920] libata version 3.00 loaded.
    [    0.452110] usbcore: registered new interface driver usbfs
    [    0.457750] usbcore: registered new interface driver hub
    [    0.463209] usbcore: registered new device driver usb
    [    0.468948] pps_core: LinuxPPS API ver. 1 registered
    [    0.474027] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.483368] PTP clock support registered
    [    0.487404] EDAC MC: Ver: 3.0.0
    [    0.490920] scmi_core: SCMI protocol bus registered
    [    0.496209] FPGA manager framework
    [    0.499761] Advanced Linux Sound Architecture Driver Initialized.
    [    0.506965] vgaarb: loaded
    [    0.510095] clocksource: Switched to clocksource arch_sys_counter
    [    0.516569] VFS: Disk quotas dquot_6.6.0
    [    0.520602] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.534697] Carveout Heap: Exported 192 MiB at 0x00000000ac200000
    [    0.541031] NET: Registered PF_INET protocol family
    [    0.546163] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.555336] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.564124] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.572054] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.580246] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.588119] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.594948] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.601854] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.609329] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.615565] RPC: Registered named UNIX socket transport module.
    [    0.621640] RPC: Registered udp transport module.
    [    0.626449] RPC: Registered tcp transport module.
    [    0.631254] RPC: Registered tcp-with-tls transport module.
    [    0.636857] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.643443] NET: Registered PF_XDP protocol family
    [    0.648354] PCI: CLS 0 bytes, default 64
    [    0.653735] Initialise system trusted keyrings
    [    0.658505] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.665385] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.671619] NFS: Registering the id_resolver key type
    [    0.676825] Key type id_resolver registered
    [    0.681100] Key type id_legacy registered
    [    0.685216] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.692066] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.752538] Key type asymmetric registered
    [    0.756738] Asymmetric key parser 'x509' registered
    [    0.761778] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.769516] io scheduler mq-deadline registered
    [    0.774154] io scheduler kyber registered
    [    0.778280] io scheduler bfq registered
    [    0.785471] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.792111] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.799451] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.812031] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.827239] loop: module loaded
    [    0.831559] megasas: 07.727.03.00-rc1
    [    0.839640] tun: Universal TUN/TAP device driver, 1.6
    [    0.845938] VFIO - User Level meta-driver version: 0.3
    [    0.852634] usbcore: registered new interface driver usb-storage
    [    0.859472] i2c_dev: i2c /dev entries driver
    [    0.865030] sdhci: Secure Digital Host Controller Interface driver
    [    0.871363] sdhci: Copyright(c) Pierre Ossman
    [    0.876078] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.882654] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.890163] usbcore: registered new interface driver usbhid
    [    0.895869] usbhid: USB HID core driver
    [    0.901218] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    [    0.911717] optee: probing for conduit method.
    [    0.916303] optee: revision 4.6 (71785645fa6ce42d)
    [    0.916648] optee: dynamic shared memory is enabled
    [    0.927217] optee: initialized driver
    [    0.927314] random: crng init done
    [    0.933113] Initializing XFRM netlink socket
    [    0.938864] NET: Registered PF_PACKET protocol family
    [    0.944106] Key type dns_resolver registered
    [    0.957004] registered taskstats version 1
    [    0.961463] Loading compiled-in X.509 certificates
    [    0.977682] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.9-v11.01.09 (Fancy Rat)')
    [    1.035985] omap_i2c 4900000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.042769] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.050190] pca953x 2-0023: supply vcc not found, using dummy regulator
    [    1.057081] pca953x 2-0023: using AI
    [    1.074151] pca953x 2-0023: failed writing register: -121
    [    1.079842] pca953x 2-0023: probe with driver pca953x failed with error -121
    [    1.087409] omap_i2c 20000000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.093465] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    1.102052] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.111281] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.125564] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.133986] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16)
    [    1.144807] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.155600] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.165711] printk: legacy console [ttyS2] disabled
    [    1.171028] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 228, base_baud = 3000000) is a 8250
    [    1.179982] printk: legacy console [ttyS2] enabled
    [    1.189703] printk: legacy bootconsole [ns16550a0] disabled
    [    1.205382] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.212387] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.217789] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.224535] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.230937] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.237402] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.243598] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.250412] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.256891] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.263875] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
    [    1.271228] spi-nor spi0.0: chipselect 0 already in use
    [    1.276462] spi_master spi0: spi_device register error /bus@f0000/bus@fc00000/spi@fc40000/nand@0
    [    1.285260] spi_master spi0: Failed to create SPI device for /bus@f0000/bus@fc00000/spi@fc40000/nand@0
    [    1.295123] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.309317] dwc3 31000000.usb: Configuration mismatch. dr_mode forced to gadget
    [    1.320340] mmc0: CQHCI version 5.10
    [    1.364730] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.383419] vcc0v85_ram_buck3: Bringing 750000uV into 850000-850000uV
    [    1.406872] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.420883] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    1.427252] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.434388] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.441573] mmc0: Command Queue Engine enabled
    [    1.442494] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:1
    [    1.446053] mmc0: new HS200 MMC card at address 0001
    [    1.460732] mmcblk0: mmc0:0001 8GUF4R 7.28 GiB
    [    1.470459] Alternate GPT is invalid, using primary GPT.
    [    1.475870]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
    [    1.486746] mmcblk0boot0: mmc0:0001 8GUF4R 31.9 MiB
    [    1.493044] mmcblk0boot1: mmc0:0001 8GUF4R 31.9 MiB
    [    1.499660] mmcblk0rpmb: mmc0:0001 8GUF4R 4.00 MiB, chardev (238:0)
    [    1.506116] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.517669] clk: Disabling unused clocks
    [    1.526919] PM: genpd: Disabling unused power domains
    [    1.532065] ALSA device list:
    [    1.535102]   No soundcards found.
    [    1.548778] EXT4-fs (mmcblk0p13): orphan cleanup on readonly fs
    [    1.555090] EXT4-fs (mmcblk0p13): mounted filesystem d87f5611-b496-43b6-9088-71a61aa702c9 ro with ordered data mode. Quota mode: none.
    [    1.567249] VFS: Mounted root (ext4 filesystem) readonly on device 179:13.
    [    1.574401] devtmpfs: mounted
    [    1.578169] Freeing unused kernel memory: 2752K
    [    1.582789] Run /sbin/init as init process
    [    1.586893]   with arguments:
    [    1.586897]     /sbin/init
    [    1.586901]   with environment:
    [    1.586905]     HOME=/
    [    1.586909]     TERM=linux
    [    1.677194] systemd[1]: System time before build time, advancing clock.
    [    1.705463] NET: Registered PF_INET6 protocol family
    [    1.711398] Segment Routing with IPv6
    [    1.715128] In-situ OAM (IOAM) with IPv6
    [    1.737606] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    1.769496] systemd[1]: Detected architecture arm64.
    [    1.783281] systemd[1]: Hostname set to <spartan-a>.
    [    1.790584] systemd[1]: Initializing machine ID from random generator.
    [    1.797374] systemd[1]: Installed transient /etc/machine-id file.
    [    2.198597] systemd[1]: Queued start job for default target Multi-User System.
    [    2.238570] systemd[1]: Created slice Slice /system/getty.
    [    2.260008] systemd[1]: Created slice Slice /system/modprobe.
    [    2.279967] systemd[1]: Created slice Slice /system/serial-getty.
    [    2.299962] systemd[1]: Created slice Slice /system/systemd-fsck.
    [    2.319996] systemd[1]: Created slice Slice /system/systemd-makefs.
    [    2.339486] systemd[1]: Created slice User and Session Slice.
    [    2.358538] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    2.378430] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.398293] systemd[1]: Expecting device /dev/disk/by-partlabel/data...
    [    2.418194] systemd[1]: Expecting device /dev/disk/by-partlabel/update...
    [    2.438306] systemd[1]: Reached target Path Units.
    [    2.450246] systemd[1]: Reached target Remote File Systems.
    [    2.466237] systemd[1]: Reached target Slice Units.
    [    2.478240] systemd[1]: Reached target Swaps.
    [    2.491019] systemd[1]: Listening on Syslog Socket.
    [    2.503376] systemd[1]: Listening on Journal Audit Socket.
    [    2.522812] systemd[1]: Listening on Journal Socket (/dev/log).
    [    2.542893] systemd[1]: Listening on Journal Socket.
    [    2.559045] systemd[1]: Listening on Network Service Netlink Socket.
    [    2.579008] systemd[1]: Listening on udev Control Socket.
    [    2.598746] systemd[1]: Listening on udev Kernel Socket.
    [    2.614815] systemd[1]: Listening on User Database Manager Socket.
    [    2.658473] systemd[1]: Mounting Huge Pages File System...
    [    2.673802] systemd[1]: Mounting POSIX Message Queue File System...
    [    2.694188] systemd[1]: Mounting Kernel Debug File System...
    [    2.706846] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    2.723730] systemd[1]: Mounting Temporary Directory /tmp...
    [    2.747044] systemd[1]: Starting Create List of Static Device Nodes...
    [    2.770735] systemd[1]: Starting Load Kernel Module configfs...
    [    2.794794] systemd[1]: Starting Load Kernel Module drm...
    [    2.811229] systemd[1]: Starting Load Kernel Module fuse...
    [    2.839386] systemd[1]: Starting Journal Service...
    [    2.846368] fuse: init (API version 7.41)
    [    2.854968] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
    [    2.868452] systemd[1]: Starting Generate network units from Kernel command line...
    [    2.890792] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    2.914855] systemd[1]: Starting Apply Kernel Variables...
    [    2.931789] systemd-journald[110]: Collecting audit messages is enabled.
    [    2.934818] systemd[1]: Starting Coldplug All udev Devices...
    [    2.951677] EXT4-fs (mmcblk0p13): re-mounted d87f5611-b496-43b6-9088-71a61aa702c9.
    [    2.967505] systemd[1]: Mounted Huge Pages File System.
    [    2.991121] systemd[1]: Mounted POSIX Message Queue File System.
    [    3.011000] systemd[1]: Started Journal Service.
    [    3.271530] systemd-journald[110]: Received client request to flush runtime journal.
    [    3.508303] audit: type=1334 audit(1748544503.828:2): prog-id=6 op=LOAD
    [    3.515129] audit: type=1334 audit(1748544503.836:3): prog-id=7 op=LOAD
    [    4.161875] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    4.169333] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    4.176341] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [    4.191246] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100
    [    4.214332] mc: Linux media interface: v0.10
    [    4.230702] videodev: Linux video capture interface: v2.00
    [    4.276840] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@a6200000
    [    4.303244] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
    [    4.311343] remoteproc remoteproc0: 7e000000.dsp is available
    [    4.315061] platform 79000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    4.326399] remoteproc remoteproc0: Direct firmware load for j722s-c71_0-fw failed with error -2
    [    4.334291] platform 79000000.r5f: configured R5F for IPC-only mode
    [    4.341434] remoteproc remoteproc0: powering up 7e000000.dsp
    [    4.347980] platform 79000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
    [    4.353280] remoteproc remoteproc0: Direct firmware load for j722s-c71_0-fw failed with error -2
    [    4.364419] k3-dsp-rproc 7e200000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@a8200000
    [    4.370044] remoteproc remoteproc0: request_firmware failed: -2
    [    4.378571] remoteproc remoteproc1: 79000000.r5f is available
    [    4.379121] k3-dsp-rproc 7e200000.dsp: configured DSP for remoteproc mode
    [    4.379341] remoteproc remoteproc2: 7e200000.dsp is available
    [    4.379526] remoteproc remoteproc2: Direct firmware load for j722s-c71_1-fw failed with error -2
    [    4.379542] remoteproc remoteproc2: powering up 7e200000.dsp
    [    4.379575] remoteproc remoteproc2: Direct firmware load for j722s-c71_1-fw failed with error -2
    [    4.379584] remoteproc remoteproc2: request_firmware failed: -2
    [    4.430842] remoteproc remoteproc1: attaching to 79000000.r5f
    [    4.438951] Unable to handle kernel paging request at virtual address ffff800085ffffff
    [    4.452548] vdec 30210000.video-codec: Direct firmware load for cnm/wave521c_k3_codec_fw.bin failed with error -2
    [    4.455448] Mem abort info:
    [    4.463501] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    4.465884]   ESR = 0x0000000096000007
    [    4.471093] vdec 30210000.video-codec: request_firmware, fail: -2
    [    4.474832]   EC = 0x25: DABT (current EL), IL = 32 bits
    [    4.474847]   SET = 0, FnV = 0
    [    4.474851]   EA = 0, S1PTW = 0
    [    4.484526] vdec 30210000.video-codec: wave5_vpu_load_firmware, fail: -2
    [    4.486261]   FSC = 0x07: level 3 translation fault
    [    4.486268] Data abort info:
    [    4.486270]   ISV = 0, ISS = 0x00000007, ISS2 = 0x00000000
    [    4.486274]   CM = 0, WnR = 0, TnD = 0, TagAccess = 0
    [    4.486279]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
    [    4.486283] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000083196000
    [    4.486289] [ffff800085ffffff] pgd=0000000000000000, p4d=1000000083634003, pud=1000000083635003, pmd=10000000871ff003, pte=0000000000000000
    [    4.495015] vdec 30210000.video-codec: probe with driver vdec failed with error -2
    [    4.499258] Internal error: Oops: 0000000096000007 [#1] PREEMPT SMP
    [    4.557304] Modules linked in: rti_wdt k3_j72xx_bandgap rtc_ti_k3 wave5 ti_k3_r5_remoteproc(+) videobuf2_dma_contig v4l2_mem2mem ti_k3_dsp_remoteproc ti_k3_common videobuf2_v4l2 videobuf2_memops videobuf2_common cdns_dsi drm_kms_helper videodev snd_soc_davinci_mcasp sa2ul snd_soc_tlv320aic3x_i2c snd_soc_ti_udma snd_soc_tlv320aic3x snd_soc_ti_edma cdns_dphy mcrc64 snd_soc_ti_sdma mc omap_hwspinlock omap_mailbox overlay fuse drm drm_panel_orientation_quirks backlight ipv6
    [    4.598980] CPU: 3 UID: 0 PID: 178 Comm: (udev-worker) Not tainted 6.12.35-ti-00953-ge45814a3425b-dirty #1
    [    4.608628] Hardware name: Hirain spartan (DT)
    [    4.613065] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [    4.620014] pc : rproc_handle_resources.constprop.0+0x64/0x18c
    [    4.631387] lr : rproc_boot+0x37c/0x584
    [    4.636507] sp : ffff8000823eb640
    [    4.639812] x29: ffff8000823eb640 x28: ffff800081623f00 x27: ffff000007276f80
    [    4.646943] x26: 0000000000000000 x25: 0000000000000001 x24: ffff800085ffffff
    [    4.654070] x23: 0000000000000000 x22: ffff000003fc1038 x21: ffff800081565388
    [    4.661197] x20: 0000000000000000 x19: ffff000003fc1000 x18: 0000000000000001
    [    4.668324] x17: 0000000000000068 x16: 0000000000000100 x15: ffffffffffffffff
    [    4.675451] x14: ffffffffffffffff x13: ffffffffffffffff x12: ffffffffffffffff
    [    4.682578] x11: ffffffffffffffff x10: ffffffffffffffff x9 : ffffffffffffffff
    [    4.689705] x8 : ffffffffffffffff x7 : ffffffffffffffff x6 : ffffffffffffffff
    [    4.696831] x5 : ffff000007275d00 x4 : ffff800086000000 x3 : 00000000000000fd
    [    4.703957] x2 : 00000000ffffffff x1 : ffff800086000003 x0 : ffff800086000000
    [    4.711084] Call trace:
    [    4.713521]  rproc_handle_resources.constprop.0+0x64/0x18c
    [    4.718999]  rproc_boot+0x37c/0x584
    [    4.722481]  rproc_add+0x184/0x190
    [    4.725874]  devm_rproc_add+0x24/0x88
    [    4.729530]  k3_r5_probe+0x978/0xeec [ti_k3_r5_remoteproc]
    [    4.735016]  platform_probe+0x68/0xc4
    [    4.738671]  really_probe+0xbc/0x29c
    [    4.742241]  __driver_probe_device+0x78/0x12c
    [    4.746590]  driver_probe_device+0xd8/0x15c
    [    4.750766]  __driver_attach+0x90/0x19c
    [    4.754594]  bus_for_each_dev+0x7c/0xe0
    [    4.758423]  driver_attach+0x24/0x30
    [    4.761991]  bus_add_driver+0xe4/0x208
    [    4.765732]  driver_register+0x5c/0x124
    [    4.769561]  __platform_driver_register+0x24/0x30
    [    4.774254]  k3_r5_rproc_driver_init+0x20/0x1000 [ti_k3_r5_remoteproc]
    [    4.780773]  do_one_initcall+0x80/0x1c8
    [    4.784601]  do_init_module+0x58/0x1fc
    [    4.788343]  load_module+0x1bcc/0x1d8c
    [    4.792084]  init_module_from_file+0x88/0xcc
    [    4.796346]  __arm64_sys_finit_module+0x148/0x324
    [    4.801041]  invoke_syscall+0x48/0x10c
    [    4.804783]  el0_svc_common.constprop.0+0xc0/0xe0
    [    4.809478]  do_el0_svc+0x1c/0x28
    [    4.812786]  el0_svc+0x28/0x98
    [    4.815838]  el0t_64_sync_handler+0x120/0x12c
    [    4.820185]  el0t_64_sync+0x190/0x194
    [    4.823843] Code: 6b020063 8b22c098 91001301 540007c4 (b862c880)
    [    4.829922] ---[ end trace 0000000000000000 ]---
    [    4.851259] CAN device driver interface
    [    4.869044] rpmsg_can_probe: v.0 enter!
    [    4.875583] net can0: can_id is 0 dev 4e98000
    [    4.894693] rpmsg_can_probe: v.0 enter!
    [    4.899206] net can1: can_id is 1 dev 58a8000
    [    4.903869] rpmsg_can_probe: v.0 enter!
    [    4.908351] net can2: can_id is 2 dev 59a0000
    [    4.913005] rpmsg_can_probe: v.0 enter!
    [    4.917488] net can3: can_id is 3 dev 59b8000
    [    4.922619] rpmsg_can_probe: v.0 enter!
    [    4.927132] net can4: can_id is 4 dev 7030000
    [    4.931798] rpmsg_can_probe: v.0 enter!
    [    4.936275] net can5: can_id is 5 dev 4fd0000
    [    4.940938] rpmsg_can_probe: v.0 enter!
    [    4.945413] net can6: can_id is 6 dev 7228000
    [    4.950463] rpmsg_can_probe: v.0 enter!
    [    5.495999] EXT4-fs (mmcblk0p18): mounted filesystem 810ed8db-9251-49c6-beb8-3a4d0864405f r/w with ordered data mode. Quota mode: none.
    [    5.559830] EXT4-fs (mmcblk0p16): mounted filesystem 41bce95d-d1ae-492a-9c5f-4fbf11d46ab2 r/w with ordered data mode. Quota mode: none.
    [    5.779348] audit: type=1334 audit(1748544506.100:4): prog-id=8 op=LOAD
    [    5.814331] audit: type=1334 audit(1748544506.136:5): prog-id=9 op=LOAD
    [    5.859744] audit: type=1334 audit(1748544506.180:6): prog-id=10 op=LOAD
    [    5.866607] audit: type=1334 audit(1748544506.188:7): prog-id=11 op=LOAD
    [    5.873431] audit: type=1334 audit(1748544506.192:8): prog-id=12 op=LOAD
    [    6.504352] audit: type=1334 audit(1748544506.824:9): prog-id=13 op=LOAD
    [    6.511493] audit: type=1334 audit(1748544506.832:10): prog-id=14 op=LOAD
    [    6.519131] audit: type=1334 audit(1748544506.840:11): prog-id=15 op=LOAD
    [    6.699882] audit: type=1334 audit(1748544507.020:12): prog-id=16 op=LOAD
    [    6.803847] cgroup: Unknown subsys name 'memory'
    [    6.863491] file system registered
    [    6.942627] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    6.961387] ffs_data_put(): freeing
    [    6.972735] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    6.979339] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    6.986754] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    6.995605] cfg80211: failed to load regulatory.db
    [    7.042061] read descriptors
    [    7.045418] bcdVersion must be 0x0100, stored in Little Endian order. Userspace driver should be fixed, accepting 0x0001 for compatibility.
    [    7.059001] read strings
    [    7.177365] audit: type=1334 audit(1748544507.496:13): prog-id=17 op=LOAD
    [    7.211688] am65-cpsw-nuss 8000000.ethernet eth0: configuring for fixed/sgmii link mode
    [    7.220011] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [   17.316023] platform 4e230000.dma-controller: deferred probe pending: platform: supplier 4e400000.interrupt-controller not ready
    [   17.327607] platform regulator-mmc1: deferred probe pending: platform: supplier 2-0023 not ready
    [   17.336389] platform fa00000.mmc: deferred probe pending: platform: supplier regulator-mmc1 not ready
    [   17.345612] platform 4e400000.interrupt-controller: deferred probe pending: (reason unknown)
    [   17.354051] platform can-phy2: deferred probe pending: platform: supplier 2-0023 not ready
    [   17.362314] platform connector-dp0: deferred probe pending: platform: supplier regulator-dp0-prw not ready
    [   17.371965] platform regulator-dp0-prw: deferred probe pending: reg-fixed-voltage: can't get GPIO
    [   17.380835] platform fd20000.e5010: deferred probe pending: (reason unknown)
    [   17.387883] platform 30500000.dsi: deferred probe pending: (reason unknown)
    [   27.869859] audit: type=1006 audit(1748544528.188:14): pid=377 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   27.883354] audit: type=1300 audit(1748544528.188:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=7 a1=fffffd217168 a2=1 a3=1 items=0 ppid=1 pid=377 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   27.910914] audit: type=1327 audit(1748544528.188:14): proctitle="(systemd)"
    [   27.935054] audit: type=1334 audit(1748544528.256:15): prog-id=18 op=LOAD
    [   27.941886] audit: type=1300 audit(1748544528.256:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffd88cc9c8 a2=90 a3=0 items=0 ppid=1 pid=377 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   27.968701] audit: type=1327 audit(1748544528.256:15): proctitle="(systemd)"
    [   27.975804] audit: type=1334 audit(1748544528.256:16): prog-id=18 op=UNLOAD
    [   27.982801] audit: type=1300 audit(1748544528.256:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff89fb9c60 items=0 ppid=1 pid=377 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   28.009417] audit: type=1327 audit(1748544528.256:16): proctitle="(systemd)"
    [   28.016551] audit: type=1334 audit(1748544528.256:17): prog-id=19 op=LOAD
    I can observe from the Logs that you are configuring the device in Fixed Link mode from the device tree. It doesn't mean that Link is up with 1000Mbps.
    As the device is configured with a fixed-link property, Linux populates the Link is Up with 1000Mbps.
    Can you please dump CPSW SGMII registers and check Link status?
    Sudheer
    Is CPSW3_CPSW_NU_CPSW_NU_ETH_MAC_1_PN_MAC_CONTROL_REG the control register for port2?
    The issue has been resolved. Currently, in TI's native code, the SGMII registers are configured for auto-negotiation, so both ends negotiate to 10Mbps. I configured the registers to fixed mode (setting CPSW3_CPSGMII_MR_ADV_ABILITY_REG_j to 0x9801 and CPSW3_CPSGMII_CONTROL_REG_j to 0x20), achieving a bandwidth of up to 950Mbps. Is there a patch available that supports both auto-negotiation and fixed-link modes?
    No, There is no patch available for forcing SGMII with 1000Gbps, Full Duplex.
    Above is valid for MAC to MAC connection and where Auto-negotiation is not supported.
    As you are both side TDA4 device, only change required will be configuring one side as SGMII Master with Auto-negotiation and other side as Slave with Auto-negotiation.
    Sudheer
  • "only change required will be configuring one side as SGMII Master with Auto-negotiation"
    ==>Should bit 5 of CPSW3_CPSGMII_CONTROL_REG_j be set to 1? That is, does setting 1 correspond to master and 0 correspond to slave?
    Yes. Enable one side as the Master and the other side as the Slave, and check with Auto-negotiation enabled.
    Sudheer
