Hi all,
We have a question as following;
We have the reply from you as following;
"For the CAN transceiver, the total load can exceed 60 Ohm, it is reasonable if the total load is between 45 Ohm and 65 Ohm."
Please refer to "http://e2e.ti.com/support/interface/industrial_interface/f/142/p/403178/1430042#1430042".
If total load is less than 45ohm, what kind of problem will be happened?
-FC will increases,
-Consumption current increases, so device will be hotter
-Cable impedance miss-match will be occurred, so reflection will be occurred
If you have some information, could you let us know?
Kind regards,
Hirotaka Matsumoto
