TPS2553-Q1: reverse voltage clarify
Part Number: TPS2553-Q1
Other Parts Discussed in Thread: TPS2553
One of my customer ask me the following:
The component has reverse voltage protection and when it is turned on (Vou> vin), FAULT goes down and the switch goes to OFF (before it was ON) it is clear to me from the specifications.
My case is different from what happens when the switch is already in OFF mode (EN pin at 0) and I give the reverse voltage Is either FAULT then going to 0 or not.
Because in my understanding this is a normal case? This situation is not described in the specification (or I did not find it) can you check?
Can you please advise the above question,  I will really appreciate it.
Thanks in advance.
Kind Regards,
Shai Berman
