TUSB4020BI: Configure slave address if use two TUSB4020BI
Part Number: TUSB4020BI
Hi Team,
According to the datasheet, the bit 2 of slave address could be configured by pin GANGED/SMBA2/HS_UP.
However, the following picture describes that SMBus slave address bits 2 and 3 are always 1 for the TUSB4020BI.
Based on the same FULLPWRMGMTz/SMBA1 configuration, if we have two TUSB4020BIs on the same SMbus,
How do we configure their slave address to different number?
  • Hi Ray,
    The customer can change FULLPWRMGMTz/SMBA1 to differentiate the devices. The SMBUS setting of the fullpwrmgmt bit in the register will overrride the FULLPWRMGMTz pin setting.
    JMMN
  • Hi JMMN,
    No problem for SMBA1 pin setting. .
    Can SMBA2 pin also determine tusb4020b slave address ?
    Another question. Does 8 inch mean uplink+downlink total ?
    Minimize the trace lengths of the differential pair traces. Eight inches is the maximum recommended trace
    length for USB 2.0 differential-pair signals. Longer trace lengths require very careful routing to assure proper
    signal integrity.
    TKS !
  • Hi Terry,
    From my lab test today, it looks like SMBA2 pin will also affect the SMBUS address. I am trying to determine where the note in the datasheet originated.
    8 inch pcb trace length is from connector to hub, so:
    upstream connector - 8 inch of PCB trace - hub - 8 inch of PCB trace - downstream connector
    JMMN
