Part Number: TUSB1042I
Other Parts Discussed in Thread: TUSB321AI
According to the Pin Configuration/Function table on page3 of the datasheet (SLLSF15D), it seems as if the TypeC connections (Tx1/Rx1/Tx2/Rx2) are only used for Downstream Facing Port mode.
The front page "Simplified Schematics" diagram also shows the TUSB1042I connected to a USB Host (DFP).
However, I'd like to be able to use this chip in a UFP mode, where I connect TypeC (4 channel) upstream to a Host and TypeA (2 channel) downstream to a Hub.
Is this possible?
It seems like you have this exact configuration depicted in the Figure 22/Figure 23 example, showing this chip used in both UFP/DFP modes, on either side of the TypeC cable connections.
Are there any special settings or limitations in using this chip to function in UFP mode?
Thanks for any pointers.
-- Atsushi
