Part Number: DP83867IS
Hi Team,
Could you tell me the SGMII OUTPUT Output Differential Voltage?
(Is it equivalent to DP 83869 HM?)
Hi Team,
DP83867IS follows the SGMII standard and the output differential voltage will be between 150mV to 400mV.
-Regards
Aniruddha
Is 200mVpp or more guaranteed?
(The input voltage range of the intended connected SGMII receiver must be 200 mVpp or higher.)
Hi,Aniruddha
As for SGMII output differential voltage, is 200 mVpp or more guaranteed?
(The receiver intended for connection must have an input voltage range of at least 200 mVpp.)
Unfortunately, it would not be possible to guarantee 200mVpp because SGMII standard allows voltage to drop till 150mVpp.
-Regards
Aniruddha
