DP83848I X1 CLKin and CLK_OUT
Other Parts Discussed in Thread: DP83848I
Running the DP83848I in RMII mode.
Is it acceptable to feed the X1 pin of the DP83848I with a 50MHz clk (from an oscillator), and then use the CLK_OUT pin from the DP83848I as the clock in pin to the MAC?
Or does the 50MHz clk from the oscillator need to be fed to the MAC and the DP83848I  (and not use the CLK_OUT pin on the DP83848I).
Ro
