Other Parts Discussed in Thread: DP83640
I use dp83640 for ptp time adjust.
When there is a large negative change, the PPS is disappeared.
I see these words in Sofrware Development Guide 3.1.4.6
If a large adjustment to the PTP time is made, the PPS trigger may need to be rearmed to avoid a long
period of inactivity or a period of rapid pulsing. For a large positive change in time (greater than one
second), the trigger should be rearmed to trigger at a second boundary relative to the new time, prior to
making the time adjustment. For a large negative change, the trigger should be disabled prior to making
the time adjustment, and then rearmed after making the time adjustment.
When there is a large negative change, I diable the trigger by TRIG_DIS, but after adjustment, the pps is still disappeared when i rearmed the trigger.
Is there any advise?
Thank you,
Kevin
