Other Parts Discussed in Thread: DP83TC811
Tool/software: Linux
Hi Ti:
I has layout question about DP83TC811S-Q1 .
Kernel :3.18.20
EMAC + PHY SGMII mode
start shell:
insmod $MODULE_BASE_PHY/libphy.ko
insmod $MODULE_BASE_OF/of_mdio.ko
insmod $MODULE_BASE_PHY/dp83tc811.ko
insmod $MODULE_BASE/qcom_emac.ko
ifconfig eth0 down
echo 1 > /proc/sys/net/ipv4/conf/eth0/arp_ignore
echo "arp_ignore is set" > $DUMP_TO_KMSG
ifconfig eth0 hw ether 00:80:48:BA:d1:30
ifconfig eth0 up
ethtool -s eth0 autoneg off speed 100 duplex full
console LOG:
[ 37.014068] bridge0: port 1(rndis0) entered forwarding state
[ 135.768276] emac start
[ 136.047460] get_phy_id: ----- phy_id=0x2000a253
[ 136.051452] phy_device_create: 187,set irq = PHY_POLL
[ 136.353809] USB QCMAP NL IOCTL Snd GETNEIGH Succ
[ 136.391776] arp_ignore is set
[ 136.433958] qcom-emac 7c40000.qcom,emac eth0: TX queues 1, TX descriptors 512
[ 136.451144] qcom-emac 7c40000.qcom,emac eth0: RX queues 1, Rx descriptors 256
[ 136.504147] emac_mac_up: 1926, set phydev->irq PHY_IGNORE_INTERRUPT, call phy_start
[ 136.555901] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 136.623612] USB QCMAP NL IOCTL Snd GETNEIGH Succ
[ 136.638657] qcom-emac 7c40000.qcom,emac eth0: ethtool cmd autoneg 0, speed 100, duplex 1
[ 136.669249] phy_state_machine: 851, PHY_FORCING, call genphy_update_link
[ 136.688406] ethtool (6283) used greatest stack depth: 4228 bytes left
[ 136.707804] qcom-emac 7c40000.qcom,emac eth0: ethtool cmd autoneg 0, speed 100, duplex 1
[ 136.724163] qcom-emac 7c40000.qcom,emac eth0: Link is Up - 100Mbps/Full - flow control off
[ 136.731952] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xc0 bits:0xc0
[ 136.740438] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xc0 bits:0xc0
[ 136.766931] qcom-emac 7c40000.qcom,emac eth0: ethtool cmd autoneg 0, speed 100, duplex 1
[ 136.799211] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 136.806666] start_emac_le (6205) used greatest stack depth: 4172 bytes left
[ 136.829362] QTI:Processing LINK_UP
[ 136.850811] QTI:Setup TETHERED link
[ 136.855328] QTI:ETH mode
[ 136.863435] QTI:LINK_UP message posted
136.934367] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xc0
[ 136.967441] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xdd
[ 137.028573] device eth0 entered promiscuous mode
[ 137.039735] bridge0: port 3(eth0) entered forwarding state
[ 137.044731] bridge0: port 3(eth0) entered forwarding state
[ 137.051522] qcom-emac 7c40000.qcom,emac eth0: SGMII CDR not locked
[ 137.069103] phy_state_machine: 790, PHY_UP, set needs_aneg ture
[ 137.157937] QTI:LINK_UP Processed
[ 137.262470] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xc0
[ 137.282924] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xdd
[ 137.334196] qcom-emac 7c40000.qcom,emac eth0: SGMII CDR not locked
[ 137.346847] phy_state_machine: 790, PHY_UP, set needs_aneg ture
[ 137.522075] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xc0
[ 137.547164] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xdd
[ 137.609893] qcom-emac 7c40000.qcom,emac eth0: SGMII CDR not locked
[ 137.625095] phy_state_machine: 790, PHY_UP, set needs_aneg ture
[ 137.792244] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xc0
[ 137.814598] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xdd
[ 137.871142] qcom-emac 7c40000.qcom,emac eth0: SGMII CDR not locked
[ 137.877913] phy_state_machine: 790, PHY_UP, set needs_aneg ture
[ 138.062195] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xc0
[ 138.081951] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xdd
[ 138.134355] qcom-emac 7c40000.qcom,emac eth0: SGMII CDR not locked
[ 138.148232] phy_state_machine: 790, PHY_UP, set needs_aneg ture
[ 138.342560] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xc0
[ 138.361010] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xdd
[ 138.414221] qcom-emac 7c40000.qcom,emac eth0: SGMII CDR not locked
[ 138.421319] phy_state_machine: 790, PHY_UP, set needs_aneg ture
[ 138.598881] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xc0
[ 138.618337] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xdd
[ 138.679442] qcom-emac 7c40000.qcom,emac eth0: SGMII CDR not locked
[ 138.691777] phy_state_machine: 790, PHY_UP, set needs_aneg ture
[ 138.897881] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xc0
[ 138.914776] qcom-emac 7c40000.qcom,emac eth0: error: failed clear SGMII irq: status:0xdd bits:0xdd
root@mdm9607:~# ifconfig
bridge0 Link encap:Ethernet HWaddr 22:82:88:7A:FA:6B
inet addr:192.168.225.1 Bcast:192.168.225.255 Mask:255.255.255.0
inet6 addr: fe80::2082:88ff:fe77:f768/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:543 errors:0 dropped:0 overruns:0 frame:0
TX packets:273 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:33055 (32.2 KiB) TX bytes:101481 (99.1 KiB)
eth0 Link encap:Ethernet HWaddr 00:80:48:BA:D1:30
inet addr:169.254.4.1 Bcast:169.254.4.255 Mask:255.255.255.0
inet6 addr: fe80::280:48ff:feba:d130/64 Scope:Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:108
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4312 errors:0 dropped:0 overruns:0 frame:0
TX packets:4312 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:158178 (154.4 KiB) TX bytes:158178 (154.4 KiB)
rmnet0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING MTU:2000 Metric:1
oot@mdm9607:~#
Link led keep flickering,please check it,
