Other Parts Discussed in Thread: TUSB8040A
We are seeing a high percentage of USB 3.0 Rx long channel jitter tolerance failures on the upstream port of product samples tested. The TUSB8040A downstream ports pass on all samples tested.
1. Does the TUSB8040A upstream port pass the USB 3.0 Rx long channel jitter tolerance compliance test? Is there any Sj frequencies that are marginal with this hub?
2. Has TI compiled a list of USB 3.0 B connectors that are recommended to use (signal-integrity/crosstalk) and also a list of connectors that are not recommended to use (poor signal-integrity/crosstalk)?
Test Notes:
1. We are using LeCroy SDA 830Zi-A scope with LeCroy PeRT with QualiPHY compliance software, using USB-IF USB 3.0 test fixtures.
KT
