Other Parts Discussed in Thread: LMH1219, LMH1218
Hi Team,
I see below NOTE in the LMH1226 datasheet. Could you please help us understand the CDR Reset and Release requirement ?
Q1). I understood that LMH1226 will start CTLE adaptation and CDR lock process when it loses input signal (i.e. loses lock). What would happen when the input video data is actively changed with a routing switcher ? My thought was that since the device has false lock protection function, it would start new adaptation process even changed between SMPTE data rates.
Q2). If the data rate is changed from SMPTE data rate to Ethernet, I believe the device would lose lock and starts a new adaptation/lock process automatically. So, the device would not require CDR Reset and Release. What do you think ?
Q3). Do you really need this CDR Reset and Release process every time after input data rate is changed actively (No loss of signal) ? Customer requreiment is to be used stand alone.
Q4). How long would it take for a deivce to detect "loss of signal" when input signal is disconnected ?
Kawai
