Part Number: TCA9517
Hello team,
I have several questions about TCA9517 spec items as follows.
1) Regarding the power up sequence, is the device can be ready to enable when both VCCB>2.5V and VCCA>0.8V are satisfied?
2) When we think about minimum case of the B-side low level input, it looks we can calculate it by 0.38V=0.45V-0.07V, is it correct? I'd like to know the noise margin correctly.
3) Regarding the Figure-6 on the datasheet, how come the step wise input waveform in the device timing flow. Could you kindly tell the mechanism?
Thanks in advance.
S.Sawamoto
