Part Number: DS90UB933-Q1
Hi Team,
I am working on a project for a customer and am trying to determine which serializer would be best suited for their imager. They are using OV9716, 120dB mode. I believe the color depth will be somewhere in the order of 24 bits for 120dB mode. The camera should be 1.4MP, 30FPS.
That being said, what I don’t currently understand is how to calculate if the 913A or 933 is sufficient based on overhead and blanking times, etc. Is the formula just: (Resolution) x (Frame Rate) x [(Color Depth) + Blanking/Overhead Bits] i.e. (1.4MP) x (30FPS) x (24bits).
If so, we get 1.008Gbps and should therefore use the 933. Can you please verify?
Thank you and regards,
Dan
