Other Parts Discussed in Thread: LM5157, LM5155, LM5156, TPS54308
Could I get a recommendation for any TI products that I could use to design an isolated 12V/2.5A power supply with a 24V input?
Hi Tyler,
Thank you for reaching out and considering TI solutions. You may consider the LM5157 or the LM5156 in a flyback configuration. The LM5157 has integrated MOSFET supporting a peak current of at least 6.5A, and the LM5155/56 employs external MOSFET for better thermal management. You may refer to the following design, and you can change the IC to LM5156.
https://www.ti.com/tool/PMP40555
Youhao Xi, Applications Engineering
Hi ,
Or you can try a flybuck solution with TPS54308.
app note as below:
Designing a Simple and Low-Cost Flybuck Solution With the TPS54308.pdf
BRs,
Young
