Part Number: ISO1050
Hi Team
When using ISO1050, customer found abnormal CAN communication sometimes. In contrast to normal waveform, no level change was found on the bus and there should be no data from time to time. This abnormal is not frequently, just sometime occurs.
There are no signs of burn-out, the power supply is ok, and measurement CAN pin impedance is the same as the normal chip.
Below attached the schematic, could you give me some hint to go next?
Best
