Dear team,
ISO7421 uses only one pin for PWM signal transmission. What to do with unused pins. Thank you.
Hi TTG,
Thank you for reaching out to us!
There is a weak pull-up resistor at the input.
Hence, the input will be pulled high internally if unconnected.
You can connect the unused input to ground to keep the output low if desired.
Alfred
