Part Number: ISO6740
Hi team,
Could you give me comment on following customer questions?
Q1. When the customer doesn't use 2 ch out of 4 ch, the supply current - ac signal is proportional to the number of using channel. is it correct understanding?
Q2. When the customer will make unused pins (a) be opened or (b) be shortened to gnd, or (c) be pulled up to supply, will the supply current be changed depending on which (a, b, c) case is selected? If the supply current will be different depending on the (a), (b) or (c), which case will be least in terms of the supply current?
Takeshi Sasaki
