Part Number: ISO7741
Hi team,
Could you pls share some data about the package thickness typ value? It's only have a maximum value showing in our datasheet : 2.65 MAX
Best regards
Mia Ma
Hi team,
Best regards
Mia Ma
Hi Andrew,
Actually, I am confused about the difference between the two items you are mentioned; should these two be the same thing?
From my side, My customer want to confirm the thickness to verify for the vertical component placement.
Thanks.
Best regards
Mia Ma
Hi Mia,
There is a slight difference between the two according to the packaging experts.
The molded package body thickness would just be the thickness of the insulation (leads not included), whereas distance from the bottom of the leads to the top of the package would be total device thickness.
Based on your last comment I would assume you are looking for the total thickness of the device (bottom of leads to top of package), and have requested this information from the packaging team.
-Andrew
