Digital isolator for CAN bus
Good Day.
When is a digital isolator needed for a board-to-board CAN bus? And why are they needed just when PCBs adopt different CAN transmitters?
>>> I found an application report with regarding to this query (https://www.ti.com/lit/an/slla486a/slla486a.pdf?)
How about other types of a bus are the same? For some time, if this applies for example to LVDS bus?
Please advise. Thank you very much.
Ray Vincent
  • Hi Ray,
    Thanks for reaching out.
    For a CAN Bus, isolation is typically needed for the following reasons:
    -To protect low voltage equipment and humans from high voltage surges
    -To tolerate large ground potential difference and disruptive ground loops in circuits that have high energy or are separated by a large distance
    For most communication interfaces, isolation is also needed for these reasons.
    Kenneth
