Part Number: ISO7041
Hi Team,
There is one channel which will not be used in the design. To have the lowest power consumption, should the IN pin be a no connect, pull-up, or pull-down resistor? The default output is high and from https://e2e.ti.com/support/isolation-group/isolation/f/isolation-forum/732667/faq-can-channel-input-output-pins-on-a-digital-isolator-be-left-floating it says we should do a pull-up. Can you confirm this is true for ISO7041?
Does there need to be a pull-up on both input & output pins?
Do you have an idea of how much this will save with power consumption?
Thank you,
Trent
