Part Number: SN6505B-Q1
hi expert
i saw the following parameter in datasheet.
my question is that whether is this function disable during soft-start stage?
thanks
hi expert
thanks
Hello Jay,
Thank you for reaching out. The current clamp limiting feature is available when the device is fully powered and under normal operations. The soft-start circuitry is only active at start up and when EN is enabled. As a result, you can consider these two features separate.
Andrew
