ISO7221M: Specification differences between Rev.Q and Rev.R are unclear
Part Number: ISO7221M
HI, Staff
Please let me check the specifications of ISO7221M (SLLS755R).
10 Revision History The following information is found in Rev.Q → Rev.R.
• Updated Thermal Characteristics, Safety Limiting Values, and Thermal Derating Curves to provide more
accurate system-level thermal calculations ........................4
<The specification differences between Rev.Q and Rev.R are unclear>
I compared the characteristic specifications in the Rev.Q data sheet with those in Thermal Characteristics, Safety Limiting Values, and Thermal Derating Curves, but I could not find any differences.
Please tell me which parts have been updated.
(I understand that the numbers in Figure x-x are different)
Similarly, if we focus only on ISO7221M.
• Updated electrical and switching characteristics to match device performance...............................................12
In the electrical section, is the only difference CI TEST CONDITIONS (2πft), f=2MHz?
In the switching characteristics section, have you changed only "tf" and "tr"?
regards
cafain
  • Hi Cafain,
    Thanks for reaching out.
    Yes you are correct. The main difference was the tr and tf specifications in the switching characteristics table.
    No, the old datasheet said (4E6πt), which is the same as (2πft), f=2MHz. The difference is that f=2Mhz was not separately defined, but rather combined with the equation.
    Aaditya Vittal
  • Aaditya Vittal-san
    I understand the changes in ”........12”
    I am unclear about the differences in the information above (..........4).
    Please continue to provide your support.
    regards
    cafain
  • Hi Cafain,
    You are correct, There are no specification changes. The only change is a wording change in the footnote:
    The highlighted word changed from "report" to "note". Besides this change, no other changes were present.
    Aaditya Vittal
