ISO7240C: Datasheet updates due to revision change
Guru 12805 points
Part Number: ISO7240C
The following items have been changed from revision T (SLLS868T) to revision U (SLLS868U).
• Updated reference from capacitive isolation to isolation barrier throughout the document.
 →The description "Isolation Capacitor" in the old data sheet (SLLS868T) has been changed to "Isolation Barrier" in the new data sheet (SLLS868U).
• Updated VDE V 0884-11 to DIN VDE 0884-17 throughout the document.
 →Updated from DIN VDE 0884-10 to DIN VDE 0884-17.
• Updated the numbering format for tables, figures, and cross-references throughout the document.
 →There are no additional comments regarding the above.
• Updated Thermal Characteristics, Safety Limiting Values, and Thermal Derating Curves to provide more accurate system-level thermal calculations
 →Thermal Characteristics have been updated based on the new thermal design criteria.
• Updated electrical and switching characteristics to match device performance
 →The TEST Condition in the characteristics table has been changed
Q1.
Is the above all the updates? Please let me know if there are any omissions. I have also attached the datasheets before and after the revision just to be sure.
SLLS868T.pdfSLLS868U.pdf
Q2.
Are there any items that will affect the design with the above change from T to U?
Conor
  • Hello Conor,
    Thank you for reaching out.
    Q1.
    Yes, all relevant spec changes have been reflected in the revision history.
    Q2.
    I viewed both datasheet revisions. I do not expect any of the changes to affect the design. let me know if you have any questions.
    Andrew
