ISOUSB211: Audio isolation
Part Number: ISOUSB211
In the Application Note- USB Audio Isolation with Isolated USB 2.0 Redriver
https://www.ti.com/lit/an/slla601/slla601.pdf?ts=1723650485763&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FISOUSB211
About the isolation audio circuit shows as the right image in Figure 2-1, I want to know if the grounds at both ends need to be connected together externally to form a loop after being isolated?
For example, they are connected through the outer metal shell? If a loop is not formed, will the audio not be output?
  • Hi Chang,
    Thank You for reaching out. Glad to see this ISOUSB application note coming to use for your application of interest. Now coming to your question:
    NO, the 2 isolated grounds need not be connected in any way for the successful operation of USB Peripheral Audio Output. Please refer Figure 3-2 from the same document below:
    Moreover, If you connect the 2 grounds in any way, like outer metal shell, then it will nullify the advantage of using the ISOUSB in this application as it creates a Ground Loop path again.
    Hope this helps your application use case.
    Varun
