Part Number: SN6507
Dear Teams,
I use SN6507 to design an isolated power supply with an input voltage of 5V, an output voltage of 15V, and an output current of 200mA.
Do you have a recommended transformer?
Thanks & Best regards.
Part Number: SN6507
Dear Teams,
You will find recommended and tested transformer part numbers in the data sheet and these have been identified as more common and typical voltage conversions. If you have a turns ratio, isolation requirement, etc that is not covered in section 9.2.4.2 of the SN6507 data sheet, you can work directly with any of the transformer vendors identified and they should be able to help get you samples to test.
Steve
