Part Number: ISO7041
Hi Team
The ISO7041 certificate contains a marking for a component that allows its use in a potentially explosive atmosphere for the separation of two intrinsically safe circuits: this condition is explicitly described in the certificate.
Is there an extension to the certificate that certifies the possibility of using it to separate circuits between safe areas and hazardous areas?
The 60079-11:2023 standard actually allows the use of certified components in accordance with VDE V 0884-11 for this purpose, but if you had a certificate as a component (U) the certification of the device would be simpler.
Thanks in advance
Best regards
