How to calculate the maximum output current when using TPS92630-Q1?
Other Parts Discussed in Thread: TPS92630-Q1
When using TPS92630-Q1 in the automotive rear light, usually TPS92630-Q1 is connected to the battery directly, as the battery voltage will vary from 9-16V normally. So to keep the output current of TPS92630-Q1 in constant range, how much current of TPS92630-Q1 should be set?
