i am trying to configure IMX035 1.3 Mega sensor on DM368 based camera.
i made
fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_SBGGR16; in capture.c inside dvsdk.
and in kernel i selcted decoder as WN1 in the video capture adapter type via menu config.
and data_pack to 16 bit, ccdc_data_pack data_pack = CCDC_DATA_PACK16; // inside kernel ccdc_dm365.c
ccdc_module_params ccdc_module_defaults
compress = {
.alg = CCDC_NO_COMPRESSION, //CCDC_ALAW,
Device initilazation all happening properly , but when Capture_get() call is happening inside DVSDK1.10.00.18
capture thread is getting blocked.
I debugged and found that the interrupt is not getting generated. its not entering inside
vpfe_isr() routine in davinci_vpfe.c.
i tryed to change VDINT0, VDINT1 to image height -1 inside ccdc_setwin() function at ccdc_dm365.c
vert_nr_lines1 = image_win->height - 1;
ccdc_write(vert_nr_lines, VDINT0);
ccdc_write(vert_nr_lines, VDINT1);
but still its not generating the interrupt.
my ISIF register setting as below.
./readl 0x01c71000 0x0 0x1ff
00000 00000003 00000000 00000000 00000000
00010 00000000 00000000 00000001 000004FF
00020 00000000 00000001 000003FF 0000FFFF
00030 000000FF 00000028 00000000 00000404
00040 00000000 00000000 00000000 00004E4E
00050 00000200 00000200 00000200 00000200
00060 00000000 00000000 00000000 00000000
00070 000003FF 000003FF 00000000 00000001
00080 00000009 00000000 00000002 00000000
00090 00000000 00000000 00000000 00000000
000A0 00000000 00000000 00000000 00000000
000B0 00000000 00000000 00000000 00000000
000C0 00000000 00000000 00000000 00000000
000D0 00000000 00000000 00000000 00000000
000E0 00000000 00000000 00000000 00000000
000F0 00000000 00000000 00000000 00000000
00100 00000000 00000000 00000000 00000000
00110 00000000 00000000 00000000 00000000
00120 00000000 00000000 00000000 00000000
00130 00000000 00000000 00000000 00000000
00140 00000000 00000000 00000000 00000000
00150 00000000 00000000 00000000 00000000
00160 00000000 00000000 00000000 00000000
00170 00000000 00000000 00000000 00000000
00180 00000000 00000000 00000000 00000000
00190 00000000 00000000 00000000 00000000
001A0 00000000 00000000 00000000 00000000
001B0 00000000 00000000 00000000 00000000
001C0 00000000 00000000 00000000 00000000
001D0 00000000 00000000 00000000 00000000
001E0 00000000 00000000 00000000 00000000
001F0 00000000 00000000 00000000 00000000
00200 00000000 00000000 00000000 00000000
00210 00000000 00000000 00000000 00000000
00220 00000000 00000010 00000200 00000000
00230 00000000 00000000 00000FFF 00000000
00240 00000001 00000000 00000000 00000000
00250 00000FFF 00000010 00000000 00000000
00260 00000000 00000000 00000000 00000000
00270 00000000 00000000 00000000 00000000
00280 00000000 00000000 00000000 00000000
00290 00000000 00000000 00000000 00000000
002A0 00000000 00000000 00000000 00000000
002B0 00000000 00000000 00000000 00000000
002C0 00000000 00000000 00000000 00000000
002D0 00000000 00000000 00000000 00000000
002E0 00000000 00000000 00000000 00000000
002F0 00000000 00000000 00000000 00000000
00300 00000000 00000000 00000000 00000000
00310 00000000 00000000 00000000 00000000
00320 00000000 00000000 00000000 00000000
00330 00000000 00000000 00000000 00000000
00340 00000000 00000000 00000000 00000000
00350 00000000 00000000 00000000 00000000
00360 00000000 00000000 00000000 00000000
00370 00000000 00000000 00000000 00000000
00380 00000000 00000000 00000000 00000000
00390 00000000 00000000 00000000 00000000
003A0 00000000 00000000 00000000 00000000
003B0 00000000 00000000 00000000 00000000
003C0 00000000 00000000 00000000 00000000
003D0 00000000 00000000 00000000 00000000
003E0 00000000 00000000 00000000 00000000
003F0 00000000 00000000 00000000 00000000
00400 4D010000 FFC007F8 00000000 00000000
00410 00000000 00000000 00000000 00000000
00420 00000000 00000000 00000000 00000000
00430 00000000 00000000 00000000 00000000
00440 00000000 00000000 00000000 00000000
00450 00000000 00000000 00000000 00000000
00460 00000000 00000000 00000000 00000000
00470 00000000 00000000 00000000 00000000
00480 4D010000 FFC007F8 00000000 00000000
00490 00000000 00000000 00000000 00000000
004A0 00000000 00000000 00000000 00000000
004B0 00000000 00000000 00000000 00000000
004C0 00000000 00000000 00000000 00000000
004D0 00000000 00000000 00000000 00000000
004E0 00000000 00000000 00000000 00000000
004F0 00000000 00000000 00000000 00000000
00500 00000000 00000000 00000000 00000000
00510 00000000 00000000 00000000 00000000
00520 00000000 00000000 00000000 00000000
00530 00000000 00000000 00000000 00000000
00540 00000000 00000000 00000000 00000000
00550 00000000 00000000 00000000 00000000
00560 00000000 00000000 00000000 00000000
00570 00000000 00000000 00000000 00000000
00580 00000000 00000000 00000000 00000000
00590 00000000 00000000 00000000 00000000
005A0 00000000 00000000 00000000 00000000
005B0 00000000 00000000 00000000 00000000
005C0 00000000 00000000 00000000 00000000
005D0 00000000 00000000 00000000 00000000
005E0 00000000 00000000 00000000 00000000
005F0 00000000 00000000 00000000 00000000
00600 0024FE05 00000000 00000000 00000000
00610 00000000 00000000 00000000 00000000
00620 00000000 00000000 00000000 00000000
00630 00000000 00000000 00000000 00000000
00640 000026F1 00001000 00000000 00001000
00650 00001000 00001000 00001000 00001000
00660 00001000 00001000 00001000 00001000
00670 00001000 00001000 00001000 00001000
00680 00001000 00001000 00001000 00001000
00690 00001000 00001000 00001000 00001000
006A0 00001000 00001000 00001000 00001000
006B0 00001000 00001000 00001000 00001000
006C0 00001000 00001000 00001000 00001000
006D0 00001000 00001000 00001000 00001000
006E0 00001000 00001000 00001000 00001000
006F0 00001000 00001000 00001000 00001000
00700 00000000 00000000 00000000 00000000
00710 00000000 00000000 00000000 00000000
00720 00000000 00000000 00000000 00000000
00730 00000000 00000000 00000000 00000000
00740 00000000 00000000 00000000 00000000
00750 00000000 00000000 00000000 00000000
00760 00000000 00000000 00000000 00000000
00770 00000000 00000000 00000000 00000000
00780 00000000 00000000 00000000 00000000
00790 00000000 00000000 00000000 00000000
007A0 00000000 00000000 00000000 00000000
007B0 00000000 00000000 00000000 00000000
007C0 00000000 00000000 00000000 00000000
007D0 00000000 00000000 00000000 00000000
007E0 00000000 00000000 00000000 00000000
007F0 00000000 00000000 00000000
