May I know how to fill the CC2541 AES certification for FIPS?
I need CFB mode that is 1 bit or 8 bit or 128 bit & size support/ source of counter ?
I attach the document for your check again.
Thanks.
Algorithm Information - AES
GENERIC PRODUCT INFORMATION |
Vendor Name |
Profuct/Algorithm Name |
Product/Algorithm Version |
IMPLEMENTATION INFORMATION |
Implementation |
☑ Software |
◻ Firmware |
☑ Hardware |
Operating Environment (Operating System, Hardware Part No., ect.) |
Operating System: Android Hartware Part No.: AES Coprocessor built in TI CC2541 |
Brief description of the algorithm or the product/product family in which the algorithm is implemented (350 characters max) |
To encrypt a message, the following procedure must be followed (ECB, CBC):
The AES coprocessor works on blocks of 128 bits. A block of data is loaded into the coprocessor, encryption is performed, and the result must be read out before the next block can be processed. Before each block is loaded , a dedicated start command must be sent to the coprocessor. |
TECHNICAL INFORMATION |
Mode of Operation |
Key Size Supported |
States Supported |
ECB |
☑ 128 Bits |
☑ Encryption ☑ Dencryption |
◻ 192 Bits |
◻ Encryption ◻ Dencryption |
◻ 256 Bits |
CBC |
☑ 128 Bits |
◻ 192 Bits |
◻ 256 Bits |
CFB (1-bit) |
◻ 128 Bits |
◻ 192 Bits |
◻ 256 Bits |
CFB (8-bit) |
◻ 128 Bits |
◻ 192 Bits |
◻ 256 Bits |
CFB (128-bit) |
◻ 128 Bits |
◻ 192 Bits |
◻ 256 Bits |
OFG |
☑ 128 Bits |
◻ 192 Bits |
◻ 256 Bits |
◻ Counter |
Size Supported |
◻ 128 Bits - Encryption, ◻ 192 Bits - Encryption, ◻ 256 Bits - Encryption |
Source |
◻ Internal, ◻ External |
Description of Counter Source |
