Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
SN74LVT16244B: slew rate
Part Number: SN74LVT16244B
Hi, Team:
My customer use SN74LVT16244B and found the input slew rate(14ns/v) is higer than datasheet spec(10ns/v).
They want to confirm:
1. if the 14ns/V is ok or not to SN74LVT16244BDGGR application?
2. why we limit the max slew rae in SN74LVT16244BDGGR datasheet? what is the impact if the customer's design is over this spec?
Thanks a lot!
  • Hi Andrew,
    The input transition rise or fall rate is recommended to be a maximum of 10 ns/V because of how CMOS devices work.
    There's a great application report that explains the possible downfalls of violating this spec: Implications of Slow or Floating CMOS Inputs
    As for the question of "is it ok to violate a datasheet spec" -- the answer will always be "no, but...." We can only guarantee operation of the device within datasheet specs.  A very minor deviation (such as 4ns/V input rise rate) will likely not cause any problems, however it is outside the spec, so we can't guarantee anything.
    Please let me know if I can be of further assistance.
