Hi Sirs,
Sorry to bother you.
As title, we found TXS0108E have wrong phenomenon on A4 pin.
Schematic:
If we disconnect all input /output,
A4 pin as below
VCCA = VCCB = OE = 3.3V, we could found I2C CLK had 12.54MHZ waveform, after disconnect OE level the waveform is gone (The OE have original pull down resistor).
VCCA = 1.8V, VCCB = OE = 3.3V, we could found I2C CLK had 8.8MHZ waveform, after disconnect OE level the waveform is gone (The OE have original pull down resistor).
A4 pin as below
Actually the CLK will connect with our light sensor, if it's always send these waveform that will effect our light sensor and EC communication.
We check our impedance/ x-ray, we don't saw any different between good and fail units.
The fail rate around 40/2600=1.5%
So, this waveform is normal? Could you help us explain it?
Thanks!!
