I am trying to use this SN74AUC34 device as a fanout buffer for my ADC SCLK. I had a few questions, though, regarding on how to set it up, as the datasheet doesn't give too much information.
1. How should I bypass Vcc?
2. What should I do with unused outputs? I am only using 4 of the 6.
3. For the unused inputs, it says to either pull them up to Vcc or pull them down to GND. Is one more preferable than the other?
4. Should I leave the EPAD floating or should I ground it?
Thank you very much.
