TXS02612: SDIO SDCard issue
Part Number: TXS02612
Hi All,
we are facing an issue with FPGA and SD-card slot using TXS02612 to translate from FPGA voltage level(2.5V) to SD card voltage level(3.3V).
We developed and succesfully tested several prototypes using your device (same layout/schematic) but unfortunately now this solution seems not working anymore.
Same SD Card booting on older prototypes does not work on new ones, furthermore it seems that on new prototypes different SD Cards causes different behaviour(sometimes boot sometimes not).
Analyzing the physical layer voltage levels show no significant difference, are you aware of some changes in your device layout/behaviour that may produce this issue?
Do you have any suggestion?
Best Regards
Fabio
