Other Parts Discussed in Thread: HALCOGEN
I'm working on a TFTP bootloader for the TMS570LS3137. I'm able to successfully transfer the Application bin file over the network to the MCU where it is flashed to 0x0020020. I have set up the App linker script accordingly.
However, the App fails somewhere in the _c_int00() function. Interestingly, when I add a breakpoint to the first call in _c_int00() and step through the code from there, it does actually make it to the App (RTI LED blink code).
Any ideas as to why this is occurring?
I have attached my linker script files and my bl_config.h file.
/* sys_link.cmd (Application Linker CMD) */
* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Linker Settings */
--retain="*(.intvecs)"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/* Memory Map */
MEMORY
VECTORS (X) : origin=0x00020020 length=0x00000020
FLASH0 (RX) : origin=0x00020040 length=0x0001FFC0
STACKS (RW) : origin=0x08000000 length=0x00001500
RAM (RW) : origin=0x08001500 length=0x0003EB00
/* USER CODE BEGIN (2) */
/* USER CODE END */
/* USER CODE BEGIN (3) */
/* USER CODE END */
/* Section Configuration */
SECTIONS
.intvecs : {} > VECTORS
.text : {} > FLASH0
.const : {} > FLASH0
.cinit : {} > FLASH0
.pinit : {} > FLASH0
.bss : {} > RAM
.data : {} > RAM
.sysmem : {} > RAM
/* USER CODE BEGIN (4) */
/* USER CODE END */
/* USER CODE BEGIN (5) */
/* USER CODE END */
/* Misc */
/* USER CODE BEGIN (6) */
/* USER CODE END */
/*----------------------------------------------------------------------------*//* sys_link.cmd (Bootloader) *//* *//* * Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com* * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met:** Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer.** Redistributions in binary form must reproduce the above copyright* notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution.** Neither the name of Texas Instruments Incorporated nor the names of* its contributors may be used to endorse or promote products derived* from this software without specific prior written permission.** THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.**//* *//*----------------------------------------------------------------------------*//* USER CODE BEGIN (0) *//* USER CODE END *//*----------------------------------------------------------------------------*//* Linker Settings */--retain="*(.intvecs)"/* USER CODE BEGIN (1) *//* USER CODE END *//*----------------------------------------------------------------------------*//* Memory Map */MEMORY{/* USER CODE BEGIN (2) */ VECTORS (X) : origin=0x00000000 length=0x00000020 vfill = 0xffffffff FLASH0 (RX) : origin=0x00000020 length=0x001FFFE0 vfill = 0xffffffff FLASH1 (RX) : origin=0x00200000 length=0x00200000 vfill = 0xffffffff RAM (RWX) : origin=0x08002000 length=0x0007E000 STACK (RW) : origin=0x08000000 length=0x00002000#if 0/* USER CODE END */ VECTORS (X) : origin=0x00000000 length=0x00000020 FLASH0 (RX) : origin=0x00000020 length=0x001FFFE0 FLASH1 (RX) : origin=0x00200000 length=0x00200000 STACKS (RW) : origin=0x08000000 length=0x00002000 RAM (RW) : origin=0x08002000 length=0x0007e000/* USER CODE BEGIN (3) */#endif#if 1 ECC_VEC (R) : origin=(0xf0400000 + (start(VECTORS) >> 3)) length=(size(VECTORS) >> 3) ECC={algorithm=algoL2R5F021, input_range=VECTORS} ECC_FLA0 (R) : origin=(0xf0400000 + (start(FLASH0) >> 3)) length=(size(FLASH0) >> 3) ECC={algorithm=algoL2R5F021, input_range=FLASH0 } ECC_FLA1 (R) : origin=(0xf0400000 + (start(FLASH1) >> 3)) length=(size(FLASH1) >> 3) ECC={algorithm=algoL2R5F021, input_range=FLASH1 }#endif/* USER CODE END */}/* USER CODE BEGIN (4) */ECC{ algoL2R5F021 : address_mask = 0xfffffff8 /* Address Bits 31:3 */ hamming_mask = R4 /* Use R4/R5 build in Mask */ parity_mask = 0x0c /* Set which ECC bits are Even and Odd parity */ mirroring = F021 /* RM57Lx and TMS570LCx are build in F021 */}/* USER CODE END *//*----------------------------------------------------------------------------*//* Section Configuration */SECTIONS{/* USER CODE BEGIN (5) *//* USER CODE END */ .intvecs : {} > VECTORS .text align(32) : {} > FLASH0 | FLASH1 .const align(32) : {} > FLASH0 | FLASH1 .cinit align(32) : {} > FLASH0 | FLASH1 .pinit align(32) : {} > FLASH0 | FLASH1 .bss : {} > RAM .data : {} > RAM .sysmem : {} > RAM/* USER CODE BEGIN (6) */ flashAPI: { .\Boot\Fapi_UserDefinedFunctions.obj (.text) .\Boot\bl_flash.obj (.text, .data) --library= "c:\ti\Hercules\F021 Flash API\02.01.01\F021_API_CortexR4_BE.lib" (.text, .data) } palign=8 load = FLASH0 |FLASH1, run = RAM, LOAD_START(apiLoadStart), RUN_START(apiRunStart), SIZE(apiLoadSize)/* USER CODE END */}/* USER CODE BEGIN (7) *//* USER CODE END *//*----------------------------------------------------------------------------*//* Misc *//* USER CODE BEGIN (8) *//* USER CODE END *//*----------------------------------------------------------------------------*/
/******************************************************************************* bl_config.h - The configurable parameters of the boot loader.* Author : QJ Wang. qjwang@ti.com* Date : 5-25-2019*//* Copyright (C) 2013-2019 Texas Instruments Incorporated - http://www.ti.com/ * * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */#ifndef __BL_CONFIG_H__#define __BL_CONFIG_H__//*****************************************************************************//// The following defines are used to configure the operation of the boot// loader. For each define, its interactions with other defines are described.// First is the dependencies (in other words, the defines that must also be// defined if it is defined), next are the exclusives (in other words, the// defines that can not be defined if it is defined), and finally are the// requirements (in other words, the defines that must be defined if it is// defined).//// The following defines must be defined in order for the boot loader to// operate://// One of CAN_ENABLE_UPDATE, SPI_ENABLE_UPDATE, SCI_ENABLE_UPDATE// APP_START_ADDRESS////*****************************************************************************//*****************************************************************************//// The frequency (MHz) of the crystal used to clock the microcontroller.//// This defines the crystal frequency used by the microcontroller running the// boot loader.//// Depends on: None// Exclusive of: None// Requires: None////*****************************************************************************#define TMS570LS31/* 150MHz is used in this example. If you like to use different speed, please change the PLL configuration in HALCoGen*/#define SYS_CLK_FREQ 180 //MHz, HCLK//*****************************************************************************// Selects the UART as the port for communicating with the boot loader.// Exclusive of: CAN_ENABLE_UPDATE, SPI_ENABLE_UPDATE,// Requires: UART_FIXED_BAUDRATE, BUFFER_SIZE//*****************************************************************************//#define UART_ENABLE_UPDATE//#define SPI_ENABLE_UPDATE//#define CAN_ENABLE_UPDATE//*****************************************************************************// The starting address of the application. This must be a multiple of 32K(sector size)// bytes (making it aligned to a page boundary), and can not be 0 (the first sector is // boot loader). //// The flash image of the boot loader must not be larger than this value.//*****************************************************************************#define APP_START_ADDRESS 0x0020020//*****************************************************************************// The address to store the update status of the application image// It contains Application Start Address, Application Image Size, etc////*****************************************************************************#define APP_STATUS_ADDRESS 0x0020000 /* This is must the starting address of one of flash sectors *///*****************************************************************************// Estimate the application image size. It is used to decide how many flash sectors// are erased for the application image.// The sector size is//*****************************************************************************#define APPLICATION_IMAGE_SIZE 0x40000; //256KB/* Max num bytes to be written at once. (128 bits) * Defined in TMS570LS3137 TRM section 5.1.2 */#define F021_FLASH_WRITE_WIDTH_BYTES 16/* UART is used in all the boot modes*///#if defined (UART_ENABLE_UPDATE)#define UART_BAUDRATE 115200#define UART scilinREG /* Use UART port 1 for UART boot *///#endif#if defined (SPI_ENABLE_UPDATE)#define SPI_PORT spiREG2 /*use SPI2 for SPI boot*/#endif#if defined (CAN_ENABLE_UPDATE)/* CAN1 is use in CAN bootloader example code. The baudrate is 500kbps, if you want to use other baudrate, * please configure it using HALCoGen. * * CAN Port used: DCAN1. Please configure MSG for RX, and LSG 2 for TX * Baudrate used: 500 kbps. * */#define CAN_PORT canREG1#endif#define BUFFER_SIZE 64 /*words in the data buffer used for receiving packets*///*****************************************************************************// Enables the pin-based forced update check. When enabled, the boot loader// will go into update mode instead of calling the application if a pin is read// at a particular polarity, forcing an update operation. In either case, the// application is still able to return control to the boot loader in order to// start an update. //// Requires: FORCED_UPDATE_PERIPH, FORCED_UPDATE_PORT, FORCED_UPDATE_PIN,// FORCED_UPDATE_POLARITY//*****************************************************************************#define ENABLE_UPDATE_CHECK#if defined (ENABLE_UPDATE_CHECK)//*****************************************************************************//// The GPIO port to check for a forced update. This will be one of the// GPIO_PORTx_BASE values, where "x" is replaced with the port name (A or B).// Depends on: ENABLE_UPDATE_CHECK//*****************************************************************************#define FORCED_UPDATE_PORT GPIO_PORTA_BASE//*****************************************************************************// The pin to check for a forced update. This is a value between 0 and 7.//// Depends on: ENABLE_UPDATE_CHECK//*****************************************************************************#define FORCED_UPDATE_PIN 7#endif//#define DEBUG_MSG_L3#endif // __BL_CONFIG_H__
