MSPM0L1304: JTAG Communication after downloading
Part Number: MSPM0L1304
Other Parts Discussed in Thread: MSPM0G3507
I'm trying to debug on custom board.
Downloading is OK, but when main function is started error is occurred and disconnected connection.
CORTEX_M0P: JTAG Communication Error: (Error -1001 @ 0x0) Requested operation is not supported on this device. (Emulation package 9.11.0.00128)
CORTEX_M0P: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging.
What should I check?
I checked it as below.
NRST is high, ROSC is open, VCORE is 1.2V
Thanks.
