Hi TI team,
I believe I’ve encountered a bug related to Link Time Optimization (LTO) in the tiarmlink tool when using TI ARM CGT 3.2.2 LTS.
Setup:
- Build system: CMake with Makefile generator
- Target: Sitara AM2434, using two R5 cores
- Toolchain: TI ARM Compiler Tools 3.2.2 LTS
- We build multiple static libraries and link two executables (one per core)
- LTO is enabled via the
-fltoflag
Issue:
- The build succeeds reliably when run without parallelism
- When using
--parallelwith CMake (i.e.,make -jN), the build sporadically fails during linking - The issue only occurs with
-flto; without it, the build is stable - The errors vary slightly, suggesting a possible race condition in
tiarmlink
Error Snippets:
Example 1:
[100%] Linking CXX executable CommunicationCore_lp_r5_1-0.out
../../master/ELFLNK/symbol.c:880:internal fatal error #10158: ("sprintf")
INTERNAL ERROR: ...\tiarmlnk executed an illegal instruction
This is caused by a defect in the TI Linker.
TI Customer Support may be able to suggest a workaround to avoid this.
Example 2:
[ 97%] Linking CXX executable CommunicationCore_lp_r5_1-0.out
[100%] Linking CXX executable ControllerCore_lp_r5_0-0.out
llvm-lto2: .../_Build/_Temp\100: Malformed block
tiarmclang: error: tiarmlnk command failed with exit code 1 (use -v to see invocation)
Conclusion:
This seems to point to a concurrency issue in the LTO phase of the linker. Has this been reported before? Are there known workarounds or fixes in newer versions of the toolchain?
Stefan
