Feedback on EK-TM4C129 Expanded Memory Option Booster Pack
Other Parts Discussed in Thread: EK-TM4C1294XL
Hello All,
We are planning to do an extender to the EK-TM4C129 with added NOR Flash+SRAM (external) v/s External SDRAM+Serial Flash. The performance would be lesser than the internal Flash but the code foot print could be potentially expanded,
I do want this to run through the forum to see whether it will be a good add on to the EK-TM4C129 portfolio of booster packs. Do let me know your thoughts if the extender board should be External SDRAM+Serial Flash or External Flash+External SRAM...
Amit
  • Amit,
    Thanks for making these available. We’re working on an LCD controller design and being able to directly use SDRAM is of an enormous value to us. Originally, I was debating between using just enough SRAM (for the frame buffer) and NOR Flash (for assets) in Host Bus 16 mode, or to use a large amount of SDRAM and QSPI flash, then just cache assets from the QSPI flash to the SDRAM on startup. I’ve got one of your boards coming from OSHPark, so it’ll be a good test to see if the latter method will work for us (which I suspect it will).
    I’ve got a question about the code provided with the TM4C129SDRAMNVM package. In ektm4c129_qssi_example.c you’re using SSI1, but according to the TM4C129x errata, that port can *only* be used in legacy mode! I thought, surely you hadn’t actually connected the QSPI flash to that port on the actual board, but sure enough, you have… So, am I missing something here or did you goof? Because if it can’t actually be used in quad-SPI mode, it’s not a very good evaluation, is it? =/
    Timothy
  • Hello Timothy
    I would like to point the errata LCD#02 and EPI#01. They may seem a bottleneck but only when a high performance raster LCD panel requiring a very high refresh rate is to be used along with code execution. With smart panel or LIDD mode this can be easily managed.
    Could you please clarify the same?
    Yes, we are revisiting the errata to see why this was issues and root cause for the same. So probably you may see an updated in the errata revision. However the design does work, but if you are still concerned about the errata, you may want to switch to another SSI port on the final design.
    Amit
    Yes, I’ve seen these. Unfortunately, this will be driving a high performance raster panel, at a high frame rate. The entire goal of the project is to create smart panel that the end user can easily preload with assets (graphics, fonts, etc.) and drive over a low bandwidth serial link (I2C, SPI, UART, CAN). Code execution should be able to work out of the main flash memory. The SDRAM would be used for cacheing assets (fonts, graphics, etc.) and the frame buffer. Hopefully we can work around those two issues.
    Amit Ashara said:
    Timothy Brown
    We’d store the assets (fonts, bitmaps, etc.) in QSPI flash, and when the system starts up we’d copy them to SDRAM for fast an easy access. Does this make sense?
    So, are you saying the SSI errata may not be valid?
  • Hello Timothy,
    Thanks for the clarifications and it does help working around the errata's for sure.
    For the last one it may be removed after we correctly ascertain the cause for which it was put in the document.
    Amit
  • Hi Amit,
    I am looking to add more SRAM to my development board. Can you please let me know whether you have item #1 DM-TM4C129:X SDRAM Only option is available to order. Please let me know the procedure/link to order also.
    Thanks.
    Piraba
  • Hello Piraba
    The memroy boards are not orderable. The Manufacturing files have been released on the respective TI Design which can be used to manufacture and assemble the boards
  • Hi Amit,
    Thanks for the response. Can you please provide the link to download this design if possible?
    Piraba
  • Never mind. I got it. Thanks.
    Piraba
