Silicon revision of the TM4C123GH6PM in the TM4C123GXL Launchpad
Hi, how do I know the revision of the µ-controller in the TM4C123GXL Launchpad? This is what is written on it:
     YFF
TM4C123G
H6PMI7
4CAR0TW
     G4
Knowing the target #define would help too.
Angelo
  • Hello Angelo
    The "I7" on the 3rd line would mean Industrial Temp Grade Revision 7
    Amit
  • Hi Amit, in this case the silicon revision will be TARGET_IS_TM4C123_RB0 or TARGET_IS_TM4C123_RB1 depending on the revision counting starting at zero or one. Which one should I use?
    Thanx,
    Angelo
  • Hello Angelo
    In this case it will be TARGET_IS_TM4C123_RB2
    Amit
  • Hi Amit,
    Interesting, I am using TivaWare_C_Series-2.1.1.71 and the targets defined in the ROM are the following, from the rom.h:
    // This is part of revision 2.1.1.71 of the Tiva Peripheral Driver Library.
    #ifndef __DRIVERLIB_ROM_H__
    #define __DRIVERLIB_ROM_H__
    #ifndef DEPRECATED
    // ROM selection labels changed between TivaWare 2.0.1 and 2.1.  The following
    // labels are intended to ensure backwards compatibility for applications
    // which have not yet been updated to use the replacement labels.
    #ifdef TARGET_IS_SNOWFLAKE_RA0
    #define TARGET_IS_TM4C129_RA0
    #endif
    #ifdef TARGET_IS_SNOWFLAKE_RA1
    #define TARGET_IS_TM4C129_RA1
    #endif
    #ifdef TARGET_IS_SNOWFLAKE_RA2
    #define TARGET_IS_TM4C129_RA2
    #endif
    #ifdef TARGET_IS_BLIZZARD_RA1
    #define TARGET_IS_TM4C123_RA1
    #endif
    #ifdef TARGET_IS_BLIZZARD_RA2
    #define TARGET_IS_TM4C123_RA2
    #endif
    #ifdef TARGET_IS_BLIZZARD_RA3
    #define TARGET_IS_TM4C123_RA3
    #endif
    #ifdef TARGET_IS_BLIZZARD_RB0
    #define TARGET_IS_TM4C123_RB0
    #endif
    #ifdef TARGET_IS_BLIZZARD_RB1
    #define TARGET_IS_TM4C123_RB1
    #endif
    #endif
    I downloaded what seemed to be the latest Tivaware C version from http://www.ti.com/tool/sw-tm4c
    As you can see it lacks the TARGET_IS_TM4C123_RB2 target. Is there a newer version?
    Angelo
  • Hello Angelo
    You may use TARGET_IS_TM4C123_RB1. The next version will have the update for inclusion of TARGET_IS_TM4C123_RB2
    Amit
