TMS570LS1224: SPI communication
Part Number: TMS570LS1224
Other Parts Discussed in Thread: HALCOGEN, TMS5701224
i have tms570ls1224 development board.
i want to configure SPI3 through halcogen .please guide me.
    The spiInit() shows that word length for SPIFMT0 is 16. The LTC6x datasheet says that 2-byte command and 2-byte PEC are used.
    1. cmd is defined as char
    cmd[0] = 0x07;
    cmd[1] = 0x14;
    cmd_pec = pec15_calc(2, cmd);
    cmd[2] = (uint8_t)(cmd_pec >> 8);
    cmd[3] = (uint8_t)(cmd_pec);
    2. in spi_write_array()
        uint16_t data[]
    so the SPI master TX the following data to LTC6x:
    0x0007, 0x0014, 0x00??(PEC0), and 0x00??(PEC1)
    From LTC6x side, it treats 0x00 as CMD0, and 0x07 as CMD1, ..which are not the correct commands for polling the ADC status.
    BTW, I am not familiar to LTC6x device, and can not to debug your code related to LTC6x protocol.
    1-> So where should i chaged in spiInit() so that LTC6x side,  treats 0x07 as CMD0, and 0x14 as CMD1 ?
    2-> and
     in spi_write_array() i have converted    uint16_t data[]  to    uint8_t data[]
    void spi_write_array(uint8_t len, // Option: Number of bytes to be written on the SPI port
    uint8_t data[] //Array of bytes to be written on the SPI port
    spiDAT1_t dataconfig1_t;
    dataconfig1_t.CS_HOLD = false;
    dataconfig1_t.WDEL = false;
    dataconfig1_t.DFSEL = SPI_FMT_0 ;
    dataconfig1_t.CSNR = SPI_CS_2 ;
    p=len;
    //while(HAL_SPI_GetState(&hspi6)!=HAL_SPI_STATE_READY);
    cs_low();
    // HAL_SPI_Transmit(&hspi1,data,len,5000);
    //for(p=0;p<len;p++)
    //data1[p]=data[p];
    spiSendData(spiREG3,&dataconfig1_t,len,data);
    delay_ms(10);
    //delay_sec(1);
    cs_high();
    i am waiting your response.
  • Hello Gautam,
    I am sorry that I am not able to write code to meet the communication protocol defined by LTC6x part.
    1. In HALCoGen, set the CHARLEN to be 8 bits instead of 16 bits
    2. Change the data type in SPI APIs from uint16 to uint8
    for example:
    spiTransmitData(spiBASE_t *spi, spiDAT1_t *dataconfig_t, uint32 blocksize, uint8 * srcbuff);
    3. the follow the protocol defined in LTC6x datasheet to send commands and receive data.
  • Hello Wang,
    I have already changed CHARLEN to be 8 bits.
    spiTransmitData(spiBASE_t *spi, spiDAT1_t *dataconfig_t, uint32 blocksizeuint8 * srcbuff);
    And what should i put in blocksize ?
    I can understand you are not writing or debug my code but can you give some similar example how to send 0x09 ?
    Please check once.
    If you only send 1 byte of data, the blocksize is be 1.
